07-15-2009, 05:54 AM   #1
Looking to buy Flash for K200D
As the title says i am looking for a decently priced flash that is suitable for the K200D. I will mainly be using it for portrait shots. I am still quite new to DSLR photography but am loving learning all i can.
I was looking around at the Metz 48AF-1, but i would say that would be my absolute max i am willing to spend, being a student. Any recommendations will be helpful, thanks.
07-15-2009, 12:11 PM   #2
I have nothing against Metz (currently having 3 Metz flash units myself), but beware of a severe limitation of the 48AF-1: it does not its own light sensor. This means:
- It only works in P-TTL/TTL and full manual modes.
- With a lens that is older than PKA (e.g. PK or M42 lens), P-TTL does not work. So you are stuck with full manual. You'll have to manually adjust the aperture and ISO settings depending on the distance from the camera to the subject. It's not difficult, but is clumsy.
- One of the problems of P-TTL is the pre-flash strobe; some people are sensitive to this, and thus close their eyes during the 'actual' strobe. I myself don't use P-TTL in group photos.
- If you use the flash with a non-Pentax camera, you're stuck with full manual mode. Case in point: my backup camera is a Canon G5. If my Pentax 540 didn't have auto mode, I'd have to bring my Canon flash to use with the G5 too. Another case in point: my expensive Minolta 5400HS is now next to useless with my Pentax cameras because it does not have auto mode.
If it were me, I'd buy an inexpensive used flash to use right now, just making sure that the flash has Auto mode (and of course safe trigger voltage), while saving up for a Metz 58 or a Pentax 540.
07-15-2009, 03:57 PM   #3
Thanks SOldBear,
So basically you suggest a flash with full Auto mode, that has helped a lot. Thanks, i'll keep looking around. Any other suggestions are welcomed!
Oh and btw, can you recommend any inexpensive flashes that have auto mode and a safe trigger voltage? Am i right assuming anything lower than 20 Volts is "safe" for pentax?
07-15-2009, 04:30 PM   #4
Read this thread.
It may answer your questions.
07-15-2009, 04:47 PM   #5
QuoteOriginally posted by SOldBear Quote
Read this thread.
Thanks again. I had a look and it seems the Pentax AF280T is a favorite. I take it these are compatible/safe with the K200D? (voltage wise?) They seem very cheap and are definitely worth a try. Would it be worth testing the unit with a Multimeter before placing it on the camera?
Thanks.
07-15-2009, 04:55 PM   #6
QuoteOriginally posted by brenton_ Quote
Correct. I've been using an AF200T with a K10D and just a few days ago bought an AF280T (I have too many flashes!). I can't remember the exact trigger voltage, but it is less than 6V for sure.
My favorites are actually the Nikon SB-24/25/26/28. They are powerful, feature-rich, and well built. But now that people know about them, the demand and thus the price keep growing....
Yes, it is always worth checking to make sure.
07-15-2009, 05:07 PM   #7
Thank you very much SOldBear for your help. I will try and pick up one of these within the next week. I will also purchase a cheap multimeter to test the voltage. I will post back to let you know how i went. Thanks again.
07-16-2009, 12:59 AM   #8
Just another question about the AF280T.
If i wanted to trigger the flash off-camera, is it possible to use something such as THIS (Cactus 4-Channel Wireless Flash Trigger Set V2s). If this is used, i assume the trigger voltage will not be an issue for the camera as the flash is not being fired directly from the camera's hot shoe. In case i am wrong, can somebody confirm that the Cactus trigger that is placed on the hot shoe does not produce any unsafe voltages into the camera?
I want to be able to take portrait shots with some side lighting, nothing too fancy. Any help/advice is appreciated.
07-30-2009, 07:56 PM   #9
Hi brenton
Ihave been looking for a flash for my K200D. What has ben your experience w/the AF280T? Has it worked in all facets?
camera, flash, k200d, pentax help, photography
Should I not buy a K200D now that it's discontinued? scantron Pentax DSLR Discussion 27 12-02-2009 10:35 AM
Why would you buy a K-x and keep your K200D? mrpackerguy Pentax DSLR Discussion 37 11-17-2009 01:40 PM
which flash to buy for K200d mlamandus Flashes, Lighting, and Studio 15 01-21-2009 09:48 PM
(Probably) about to buy a K200D/K10D.... DarkM Pentax DSLR Discussion 6 01-16-2009 09:40 PM
Looking to buy k200d tomypreach Pentax DSLR Discussion 4 10-28-2008 09:03 PM
All times are GMT -7. The time now is 02:43 AM. | See also: NikonForums.com, part of our network of photo forums!
