07-15-2009, 04:40 PM   #1
Barnster's Avatar
Shutter Actuations-How Do You Tell??
I own a K100D.How can you tell how many shutter actuations are on the camera please?
07-15-2009, 04:59 PM   #2
QuoteOriginally posted by Barnster Quote
Do a search for "PhotoME."
You're set if you have a PC with Windows. I don't know the answer for other operating systems.
07-15-2009, 05:57 PM   #3
Duck Dodgers's Avatar
Exiftool is multi-platform.
http://www.sno.phy.queensu.ca/~phil/exiftool/
http://en.wikipedia.org/wiki/ExifTool
07-15-2009, 08:39 PM   #4
Shutter actuations
The only place to see the number of shutter actuations is in the exif data that is attached to every image.
PhotoME and Exiftool are two popular programs to read/modify the exif data. You just load the images to your computer and use one of those tools (or one of many others) to view the exif data.
It would be nice if Pentax would have a menu option to show the shutter count on the camera's LCD screen, but so far, they haven't done that. I don't of any other camera maker who does, either.
07-21-2009, 04:53 AM   #5
I would assume that the K100 numbers the images serialy. The image number should tell the story.
07-21-2009, 05:17 AM   #6
QuoteOriginally posted by SOldBear Quote
PhotoME will do the job nicely.
You need to understand that also the factory tests are also counted for.
So, new out of the box your camera will at least report over 100 actuations.
- Bert
07-22-2009, 08:23 AM   #7
Image numbers
QuoteOriginally posted by photog Quote
I have a K10D, but I'm pretty sure that the K100D works the same way. The camera has an option to number images continuously, or to reset them every time a memory card is inserted. If you select continous numbering and insert a card from another camera and there are images on that card, it will pick up the highest number on that card and begin numbering at the next number.
So, the image number is not a reliable indicator, although it may give an approximate value. The only truly reliable value is the one in the EXIF data.
camera, pentax help, photography, shutter
Shutter actuations on Pentax DSLR sznajder Pentax DSLR Discussion 27 01-05-2011 05:25 PM
shutter actuations on an *ist DS WMBP Pentax DSLR Discussion 8 06-05-2010 05:51 AM
Counting Shutter Actuations Jatcat Pentax DSLR Discussion 3 02-07-2010 09:44 AM
Shutter Actuations. NLAlston Pentax DSLR Discussion 5 01-26-2010 10:53 AM
How to find how many shutter actuations... esman7 Troubleshooting and Beginner Help 16 06-03-2009 08:10 AM
All times are GMT -7. The time now is 08:17 AM. | See also: NikonForums.com, part of our network of photo forums!
