07-16-2009, 09:54 AM   #1
qns on super takumars mounts
Two questions:
Do super-takumar mounts with auto aperture pin need to be modified before mounting on k20d? I see that the pin sticks out even when the switch is moved to manual mode.
Do the super takumars also have coatings (I know that they dont necessarily have special multi coatings unless they specify SMC on the lens)?
Thank you for your time
Arvindh
07-16-2009, 10:28 AM   #2
I don't know, but perhaps these links can help you out:
Welcome to Bojidar Dimitrov's Pentax K-Mount Page
http://whitemetal.com/pentax/index_pentax_lenses.htmPage
Cheers, Bert
07-16-2009, 10:38 AM   #3
QuoteOriginally posted by mccarvindh Quote
no modifying needed - that pin won't interfere with K-mount cameras.
not sure, super-multi-coated, and SMC takumars have all those fancy coatings, like newer glass, but i'm not so sure about older taks. probably they have some kind of coatings. you can check that easily - non-coated lenses have clean, "white" look of reflected objects on their glass, while coated lenses have colored reflections.
07-16-2009, 11:12 AM   #4
bymyi41 and elkarrde - thank you for your response. Very helpful! Eager to shoot the takumars!
07-17-2009, 03:51 PM   #5
Just1MoreDave's Avatar
Yes they do. They were experimenting with multi-coatings through the production time, so it's hard to say exactly what coating formula was used on them. The later models are more likely to have better coatings than the earliest versions. A test in 1971 tried to determine the difference between everyone's coatings, and tested Super-Takumars along with Super-Multi-Coated models. They ended up with the same results, and discovered that Pentax had been making some Super-Takumars with the newer coatings and not changing the labels.
camera, coatings, mounts, pentax help, photography, pin, takumars
For Sale - Sold: Fistful of Super-Takumars: 2-35mm/3.5 1-55mm/1.8 southy Sold Items 6 01-22-2010 04:05 AM
For Sale - Sold: Two Super Takumars Curbster54 Sold Items 5 07-20-2009 06:55 AM
SMC coated Super Takumars? raymeedc Pentax SLR Lens Discussion 0 06-17-2009 11:24 AM
Is this a good deal for Super Takumars? Nachodog Pentax SLR Lens Discussion 10 10-14-2008 08:30 PM
Super Takumars 105 & 135 Mike Cash Post Your Photos! 8 04-03-2007 06:39 AM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
