07-24-2009, 07:40 PM   #1
MoparFreak69's Avatar
Post processing help?
Ok so I have these 2 photos. I want to make them one I really like the highlights and look of the bottle in the darker one, but I also really like how the background kinda blanked out but isnt necessarily completely white on the lighter one. I like the shadow across the bottom that kinda breaks it up a bit. How would I go about creating this effect on the darker one or cutting the brighter bottle out of the bright one and pasting in the darker bottle? I got this idea on a whim and made due with the available light as the sun was fading fast but it was in the right spot for what I wanted to do. I probably should have used a tripod and locked the position the same so cutting and pasting would have been easier but I didnt so thats why Im asking for help now.
07-25-2009, 07:08 AM   #2
Wheatfield's Avatar
Redo the shot with the camera on a tripod so that you can do an HDR rendering.
07-25-2009, 07:15 AM   #3
Lowell Goudge's Avatar
although wheatfield is correct, you can also modify carefully the contrast curves to achieve most of what you want, assuming you can;t go back and retake the picture.
If you clip a little of the highlights ( i.e. move the entire contrast curve to the left) it will remove more of the highlight detail, then you can let teh curve droop down in the middle to deepen the mid tones
clearly it only works to a point
bottle, camera, pentax help, photography
Machinery Post Processing mikro Photo Critique 19 03-16-2011 07:41 PM
Lens Correction: 15mm DA Limited (in-camera Pentax Kx processing or post-processing?) ADHWJC Digital Processing, Software, and Printing 10 11-29-2010 08:11 PM
Does this need post processing? bartonkj Digital Processing, Software, and Printing 14 09-11-2008 12:00 AM
Post Processing paolojackson Digital Processing, Software, and Printing 9 08-11-2008 05:17 PM
A try at Post Processing JLou Post Your Photos! 3 07-02-2007 01:35 AM
All times are GMT -7. The time now is 10:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
