07-25-2009, 07:55 PM   #1
manual focus ring
K200 with tamron 28-300 mm manual focus ring will not turn.
I need help.
07-25-2009, 08:31 PM   #2
pbo
pbo's Avatar
Considering that the lens is AF and it's not broken, your camera is probably set to AF?
On AF, focus ring can still be turned, but you need a bit of force (unless a lens has quick-shift focusing; your tamron doesn't). Set your camera to MF, and it will turn easily.
You can try dismounting the lens - if the ring still doesn't turn, it's probably broken.
Bo.
07-25-2009, 09:02 PM   #3
LMF
It is an AF lens and I tried to turn the ring in AF and MF setting. With a lot of force it will turn . When I remove the lens from the body it turns easily.
07-25-2009, 09:21 PM   #4
pbo
pbo's Avatar
Hm... It should be easy to turn on MF setting since the AF thingy in the body is not connected with the lens. When it's on AF, it will be hard to turn since you are turning against motor - so there's a lot of friction.
07-25-2009, 10:00 PM   #5
Marc Sabatella's Avatar
QuoteOriginally posted by LMF Quote
The *lens* is in the MF position, or the *camera*? Usually, you need to set the *camera* to MF to get MF to work.
07-26-2009, 02:28 PM   #6
LMF
I have tried the MF/AF selector switch in both positions on the camera body. Still no change with the focus ring on the lens. I'm going to assume that there is a problem with the swith on the body.
07-26-2009, 03:04 PM   #7
pbo
pbo's Avatar
Take the lens off, and see if the camera's AF shaft moves in/out when changing the position of the switch.
07-27-2009, 04:28 PM   #8
esman7's Avatar
QuoteOriginally posted by pbo Quote
oh so that's all it does..!
07-27-2009, 04:32 PM   #9
Damn Brit
Guest
Have you toggled the zoom creep lock on the side of the lens?
07-27-2009, 06:22 PM   #10
pbo
pbo's Avatar
Yep... There's something else happening in the body or electronics when you switch from AF-S to AF-C though.
How's that gonna help?
07-27-2009, 06:27 PM   #11
Damn Brit
Guest
Well I don't have my copy at them moment so I can't remember whether it affects the focus ring as well. So I just asked the question in case it helps.
Beginners have been known to get mixed up between the zoom ring and focus ring as well.
camera, focus, pentax help, photography
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
DA L 18-55mm manual focus ring too loose jamesv93 Pentax SLR Lens Discussion 2 11-28-2009 12:03 AM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
55-300mm manual focus ring jms698 Pentax SLR Lens Discussion 0 05-29-2008 12:44 PM
All times are GMT -7. The time now is 01:38 AM. | See also: NikonForums.com, part of our network of photo forums!
