07-27-2009, 09:45 PM   #1
Question about the k20d viewfinder
When I look through the viewfinder, it seems grainy rather than clear. This is especially evident when I aim at a solid surface, such as a wall or the sky.
I also see a black dot in the same place in the viewfinder that doesn't appear in any picture I take. Here's my most recent noob question: if this is dust/grit, where are the possible places for dust/grit to be that would be visible in the viewfinder? Front of lens, back of lens, mirror, sensor, viewfinder itself? Also, what do I do about it, if anything?
07-27-2009, 10:48 PM   #2
Ash
Community Manager
Ash's Avatar
By graininess, do you mean what you see through the viewfinder is sharp but has flecks of black artifacts, or is what you see through the viewfinder blurry?
If artifacts, then dust is probably caught between the viewfinder screen and the eyepiece.
If blurry, try the diopter setting.
07-28-2009, 09:32 AM   #3
Flecks of dust
It's sharp with flecks of black artifacts. When I get focus lock the object focused on is sharp. If I aim at the sky the viewfinder looks as if it has an even amount of dust on it. By even I mean that it there is no one area that is darker or lighter, the entire viewfinder seems "grainy" with a few single specks here and there. How do I address this? Thanks
07-28-2009, 09:39 AM   #4
Marc Sabatella's Avatar
The "graininess" is normal - that the texture of the screen. Without this, there would be nothing for the image to form on. It's more visible in certain kinds of light and with certain lenses than with others.
The specks is probably on the focus screen. You can try blowing it off if it's on the underside. but if it's on the top of the screen, or anywhere else above it, you'd have to remove the screen to clean it, and chances are excellent you'd make it worse rather than better. And even if you manage to get it clean today, it will just get dusty again. Dust in the viewfinder is normal with any DSLR; might as well get used to it.
07-28-2009, 10:51 AM   #5
I can get used to it
Thanks for the input. I was worried it was something wrong with the camera or lens. You're right about it being more evident in certain light, I can barely see it when I take pictures indoors even when I'm looking for it.
04-03-2014, 09:06 PM   #6
I got a used k20d. My viewfinder is not sharp and hazy...I am ok with specks but I cannot sometimes even see the focus points. Diopter is adjusted appropriately. Is there a way to make it brighter...I wear glasses and that does not help either. I purchased a seperate cup eye piece which has not arrived yet. I am comparing it to my Nikon D90...any suggestions?
camera, lens, pentax help, photography, question, viewfinder
K20D Viewfinder Question treetop flyer Troubleshooting and Beginner Help 6 11-02-2010 08:04 PM
K200D viewfinder + Katzeye VS. K20D viewfinder dugrant153 Pentax DSLR Discussion 3 07-24-2009 11:36 AM
Question: How can I use LCD as Viewfinder? AMBIVALENCE Troubleshooting and Beginner Help 15 05-27-2009 10:57 AM
K200D Viewfinder vs K20D Viewfinder cputeq Pentax DSLR Discussion 7 06-15-2008 11:57 PM
Selling LX viewfinder FE-1 - a question.... Sluggo Pentax Film SLR Discussion 1 09-28-2006 07:13 AM
All times are GMT -7. The time now is 03:47 AM. | See also: NikonForums.com, part of our network of photo forums!
