08-02-2009, 12:38 PM   #1
Changing iso with manual lens?
Just as the title states, how do I change the iso in the manual setting when using a SMC Pentax-M 50mm F2 on a k20d? I'm using the green button for the shutter speed recommendation and adjusting the shutter speed as needed. Any advice is appreciated.
Thanks
08-02-2009, 01:00 PM   #2
pbo
pbo's Avatar
Same way as you always do? Either use FN, then right button OR hold OK button and turn front wheel.
Bo.
08-02-2009, 01:18 PM   #3
I know now that holding the OK button down is not the same as pushing it down once. You were completely right, thanks for the quick response.
camera, iso, pentax help, photography, shutter
Changing ISO mid roll? dugrant153 Film Processing, Scanning, and Darkroom 23 09-10-2010 11:42 AM
Changing K-x ISO below 200 ARSLONGA VITABREV Troubleshooting and Beginner Help 3 03-23-2010 04:26 PM
ISO in Manual Mode campdog Pentax DSLR Discussion 4 11-24-2009 12:29 PM
Shortcut to changing ISO on K20D rickn Pentax DSLR Discussion 3 03-29-2009 12:08 PM
effects of changing ISO on dynamic range? Gooshin Photographic Technique 8 02-08-2008 07:29 PM
All times are GMT -7. The time now is 07:31 PM. | See also: NikonForums.com, part of our network of photo forums!
