08-06-2009, 04:07 AM   #1
Back focus ? lense vs. body ?
Howdy'
I sent my da* 50-135 for evaluation because I feel there is a back focus issue with it.
They called my back yesterday telling me that they did not found any back focus issue with it; they are asking me to send them my K200D to check the lens with it.
I don't have any issue with the K200D and my 40mm ltd.
Could it be a SDM problem with the body (bad connections)?
I will probably give them my K200D body just to be on the "safe" side and have them check it out (and also do a bit of cleaning, sensor, focus screen, ... maybe that's the issue ?)
Thanks for any inputs.
Max
08-06-2009, 04:41 AM   #2
Each lens has to be caliberated with A particular body. The lenses pass quality if they are within the +2/-2 focal points of the ideal. When you send your camera body, the camera will be caliberated to work with the body. Rest assured it will not modify your accurate settings with the 28mm
08-06-2009, 09:50 AM   #3
Senior Moderator
Parallax's Avatar
All of my lenses require some degree of calibration on both of my K20ds. One body BF slightly, the other FF. Assuming that cameras are held to the same +2/-2 standard as the lenses that means you could have as much as -4/+4 error with a particular body/lens combination. Generally speaking, that amount of error is only visible when pixel peeping. Having said that, and being the obsessive-compulsive, anal retentive, pixel peeper that I am, not having a body that allows focus correction is out of the question.
08-06-2009, 04:45 PM   #4
I dropped my K200D at the store today ... hopefully they will "see" that there is a slight problem with the K200D and the 50-135, and will be able to calibrate something and will be as precise as possible.
anyway, I'm pentax-less for a couple of weeks; if I'm really desperate, I will get a couple of film rolls and put them in my old spotmatic.
now, I will enjoy the simple life of the Sigma DP1.
body, camera, check, focus, focus lense, issue, k200d, pentax help, photography
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
Wanted - Acquired: k-x body or w/kit lense squigglytwigs Sold Items 2 10-30-2010 03:49 AM
Trying to understand front focus/back focus thing 41ants Troubleshooting and Beginner Help 16 08-31-2010 08:42 AM
Front/back focus or focus shift? fulcrumx29 Pentax SLR Lens Discussion 0 08-17-2009 04:56 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
All times are GMT -7. The time now is 03:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
