08-06-2009, 01:54 PM   #1
Noise vs resolution
I have heard a lot of discussion about noise at higher ISO settings with the Pentax K20D (and the K7). I understand that there is a trade-off between higher resolution and more noise at higher ISOs with most digital SLRs. Can noise be reduced at higher ISOs by reducing the resolution setting from 14.6 MP down to 10 MP on the K20D?
Thanks
Russ
08-10-2009, 07:49 AM   #2
AndrewG NY's Avatar
The effect of noise is usually diminished somewhat when downsizing -- you'll see lots of high-ISO web shots where the noise has been largely obliterated/processed out by the time the picture size was decreased to only 700 pixels wide. So it is possible that noise may be somewhat less apparent when the image is downsized to 10mp. With noise though generally comes a cost of reduced contrast and color accuracy. And having the camera output to 10mp doesn't do anything to eliminate the noise generated by the sensor which is still 14mp.
The camera shooting at 10mp isn't really any different than shooting at 14mp and then downsizing before storing on the card. I imagine the camera's downsizing logic works fine, but downsizing is somewhat destructive by nature. You're taking adjacent pixels and applying an algorithm to average them so an approximation of the original image will show in a smaller area. Then on your computer you would probalby do it again a second time for web posting or e-mail. You don't really want to downsize repeatedly, too much detail would be lost--I don't think I would use this as a noise reduction strategy--you're probably better off shooting full-res, then doing any noise-reduction post-processing, then resizing as desired--just once--as a last step.
But if you want to convince yourself, try it! I normally shoot RAW and wouldn't want to give up the advantages of RAW to shoot smaller sizes.
08-10-2009, 07:58 AM   #3
Gooshin's Avatar
QuoteOriginally posted by Buckeye Quote
Thanks
Russ
noise a hardware/physics issue
when you are shooting at 10mp you are still utalizing the full sensor, the output is simply different, and most definetly not better than the original RAW.
08-10-2009, 03:50 PM   #4
Thank you AndrewS and Gooshin
camera, isos, k20d, mp, noise, pentax help, photography, resolution
K-x has GOOD COLOURS, LOW NOISE and GOOD RESOLUTION ogl Pentax DSLR Discussion 79 11-27-2009 01:19 AM
K-7 resolution fulcrumx29 Pentax DSLR Discussion 11 10-07-2009 02:25 PM
Resolution, what does it mean? kevinschoenmakers Pentax SLR Lens Discussion 8 05-12-2009 12:41 PM
New year resolution Vs camera resolution Tripod General Talk 1 01-04-2009 05:10 AM
cs3 noise filter vs. noise ninja vs. ??? reknelb Pentax DSLR Discussion 0 03-04-2008 04:55 PM
All times are GMT -7. The time now is 03:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
