08-10-2009, 04:09 PM   #1
netuser's Avatar
k200d - how to put camera on auto iso from 400 to 800 ?
Hi
On k20d (just sold it to upgrade to k7) I used the front and rear wheel buttons to, for instance put auto iso between 400 and 800. On k200d there is only a back button, so how fdo I do it ?
Thanks in advance.
(Manual is in French and I can't deal with it )
08-10-2009, 04:59 PM   #2
Marc Sabatella's Avatar
If you mean you want the auto ISO to go to 400 at the lowest and 800 at the highest, you can't do that - it will always be 100 at the lowest. Seems there would be little point in setting it to 400 at the lowest. The camera won't choose an ISO below 400 if it doesn't think it can get a fast enough shutter speed, and if it *can* get a fast enough shutter speed at lower ISO, why not just let it? And if you need more control than that, then why use auto ISO at all?
08-11-2009, 12:26 AM   #3
netuser's Avatar
Thanks Marc !
08-11-2009, 12:49 AM   #4
ytterbium's Avatar
You coud trick it to set ISO200 as lower limit, by enabling extended DR - FN button, while selecting ISO.
Tv (shutter priority) mode can be used as well to ensure required speed and put more emphasis on varying ISO.
08-11-2009, 05:41 AM   #5
netuser's Avatar
QuoteOriginally posted by ytterbium Quote
I did and fit the purpose I intended.
Thanks to both !
auto, auto iso, camera, iso, k200d, pentax help, photography
Using Nikon SB-400 or SB-800 Flash. stevewig Photographic Technique 13 04-10-2013 10:08 AM
Tiger Feeding ISO 800 cdurfor Post Your Photos! 4 09-11-2009 05:25 AM
K 7 iso 800 & 1600 snooked Pentax DSLR Discussion 7 07-11-2009 08:46 AM
ISO 800 Background Mark2100 Photo Critique 4 10-26-2008 12:54 PM
Pentax K200D ISO 800 picture patrickmedina Pentax News and Rumors 5 02-05-2008 01:01 PM
All times are GMT -7. The time now is 07:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
