08-20-2009, 09:11 PM   #16
AndrewG NY's Avatar
OK, I didn't actually try this...and the flash will still fire/pre-flash at low power...but you might try setting the flash to wireless mode and set the custom setting so that built-in (RTF) flash is controller-only (not master).
Another idea: buy a cheap AF240FT or AF330FTZ flash and use them in the SB (spotbeam) mode; no flash will fire. Both flashes offer manual output as well with more power than the built-in flash but no automation on a K2000. The AF240FT is only ~$25 at KEH and the AF330FTZ (which is a somewhat better unit) will go for slightly more. I see a pretty good-looking AF240FT on eBay that will probably go for about $10 + shipping.
08-21-2009, 09:32 AM   #17
audiobomber's Avatar
QuoteOriginally posted by Eruditass Quote
I was under the impression that the flash would automatically pop up if it thought it needed it
Only in Green mode. No one in this forum should be using Green mode.
08-21-2009, 06:30 PM   #18
You are dead right about green mode". Thank you fro the clarification re the flash popping up. I always use Manual and I never discovered this.
I do press the green button to get a starting poing for exposure. The K20 is right 80% of the time. A test shot to confirm.
08-23-2009, 03:26 PM   #19
GerryL's Avatar
QuoteOriginally posted by AndrewG NY Quote
Does spotbeam mode mean a continous light just goes on or is it like the AF assist light only?
08-23-2009, 04:19 PM   #20
AndrewG NY's Avatar
QuoteOriginally posted by GerryL Quote
It does not shine continuously, it is a red beam that projects a pattern just when the camera thinks it needs it for autofocusing in low light. It would presumably be projected in the same instances where it would strobe the built-in flash but it is arguably less objectionable/disturbing and more effective than strobing the flash.
08-24-2009, 04:44 PM   #21
GerryL's Avatar
Aha! I should look into this!
Thanks Andrew!
It's like the expensive digital flashes now which can turn off the flash but still have auto-focus assist!
08-24-2009, 05:33 PM   #22
AndrewG NY's Avatar
I should mention I'm not very familiar with third-party options; there may be something more capable for the money...but I expect that for the spotbeam function to work, it would have to have been considered a Pentax-dedicated AF flash.
af, camera, flash, light, pentax help, photography
Anybody know of a accessory or fix for the K-x to add an autofocus assist light? crossover37 Pentax DSLR Discussion 29 08-22-2010 09:41 AM
Kx/K2000 Flash AF assist doesn't work in all modes? opiedog Pentax DSLR Discussion 5 09-23-2009 06:44 PM
K20D/K2000 with SDM lens or K7 for low light autofocus? swhang Pentax DSLR Discussion 17 06-21-2009 04:51 AM
Low light flash assist useless? konraDarnok Pentax DSLR Discussion 3 12-19-2008 12:49 PM
Stand alone autofocus assist light? Deni Pentax Camera and Field Accessories 6 09-29-2007 06:28 AM
All times are GMT -7. The time now is 06:28 PM. | See also: NikonForums.com, part of our network of photo forums!
