Quote: You just contradicted yourself - you did not list the green hexagon as a reason to not trip the shutter. I understood that in the first post but if you really read my post you would realize that my shutter trips without the green hexagon in AF mode.
Quote: So here you correct yourself - above you say in AF mode, you can't trip the shutter without the green hexagon. Please try to be more consistant.
Please try to be more patient and read into it instead of nitpicking. Maybe you'll understand faster that way.
Quote: "AF mode for those just means that you can trip the shutter only when subject is in focus. " which well simply wasn't true.
It is true. Assuming you're not pressing dedicated AF button, whenever you press the shutter, you also half-press the shutter, correct? So, you're activating AF by half-pressing the release button - thus not allowing the shutter go with image out of focus. That's assuming if you're not cancelling AF yourself by pressing dedicated AF button.
IF you are pressing that AF button, which on your camera is mapped to cancelling AF - then what are you complaining about? You cancelled AF yourself, so it's not working, and it's not checking if your image is in focus!
Quote: So now that I know it will not work in this camera - is this feature available on any other pentax camera? or any other brand?
It will work. It will work on any Pentax camera.
The needed ingredients are: a camera and a MF lens. If you want it to work remotely, then also a wired release.
The half-press for AF in Custom options has to be set on
ON. AF mode has to be set on
AF or whatever you got there on K2000.
NO MF, trap focus won't work in MF mode. (just in case, the lever for controlling that option is located on camera body just right of lens mount)
NOW mount a
K-Mount MF lens onto the camera. If you don't have an MF lens, you
will have to somehow block the autofocus shaft that's protruding from camera's mount at about 5 o'clock position. I'd suggest first trying to use a small piece of aluminum foil. Hint if you can't find the shaft - it looks like a flat screwdriver's tip, and it protrudes out of camera's body when you set AF mode to AF, and it goes back inside when you set camera to MF.
Now, put your camera in continuous shooting mode. Defocus your lens. Press shutter. Did it work? If so, read everything again.
If not, congratulations! That's how it's supposed to be on
any camera regardless of brand, make, whatever.
