08-21-2009, 08:41 PM   #1
issues shooting lightning
So about a month ago I got lucky and got some terrific shots of lightning. Turns out it was just luck.
Tonight I was expecting to get some great ones and the lightning flashed again and again and again....
They were all blurry. I was totally out of focus. How do you focus at night when you can't see anything???
Secondly, in most cases despite wonderously bright flashes I didn't see much of anything on the viewfinder. Yet, it turned out when uploading them that many of these basically black shots had great lightning when viewed on my PC.
Alas.. They were all blurry ....
Some advice on settings and technique please?
Thanks,
Javaslinger
08-21-2009, 08:54 PM   #2
LeDave's Avatar
There is no way you can autofocus in this condition. You will need to manual focus for this. Just manually set your focus and wait for the lightning to hit then shoot it.
08-21-2009, 09:02 PM   #3
I was trying to manually focus. But I couldn't see a think well enough to focus. I could have possibly focused on something close, but not something at a distance.
08-21-2009, 09:25 PM   #4
LeDave's Avatar
Hmm I have same problem as you then man, can't really see in the dark well enough through the viewfinder to focus manually. Seems like we are out of luck since flashlight doesn't go that far, lol.
Practice practice I guess, maybe can try practicing manual focusing at night on cars or something.
08-21-2009, 09:32 PM   #5
Damn Brit
Guest
QuoteOriginally posted by Javaslinger Quote
Did you try setting the focus to infinity?
What aperture and length of exposure were you using?
08-21-2009, 10:29 PM   #6
Wheatfield's Avatar
Set the focus to infinity and the aperture to f/8.
08-22-2009, 08:22 AM   #7
Ash
Ash's Avatar
Then boost the ISO a little to ensure the lightning strikes register clearly on your images.
08-22-2009, 01:13 PM   #8
Ex Finn.'s Avatar
Setting the kit lens (if that is what you used) to infinity will result in OOF images.
Practice in daylight and get a "feel" for the lens in manually focusing it close to infinity.
I normally get good results by focusing around green line, turning focus all the way to red puts the lens beyond infinity.
Cheers. Mike.
08-22-2009, 01:57 PM   #9
Ex Finn.'s Avatar
Settings depend on ambient light, how heavy the rain is and the strength of lightning bolts.
I have used everything from ISO 200 to 1600. F 5.6 and bigger aperture, 10 to 20 second, no 2 second mirror up.
Have fun, stay safe and dry and post some pictures.
Cheers. Mike.
08-27-2009, 02:05 PM   #10
emalvick's Avatar
QuoteOriginally posted by Ex Finn. Quote
Cheers. Mike.
It seems that a lot of automatic lenses have some focus beyond infinity. As you state, it is best to go around that green line or a little closer since the depth of field is likely to be such that you are beyond the hyperfocal distance and everything to infinity should be in focus (which is where the lightning should typically be).
08-27-2009, 03:49 PM   #11
Damn Brit
Guest
QuoteOriginally posted by emalvick Quote
If it's not, you're probably dead anyway.
08-27-2009, 06:45 PM   #12
jmc7104's Avatar
My lightning photo set up as follows; K10 seems to work best for me. Tripod set up usually shooting from inside house. Much safer that way. Af. off, Bulb mode remote cable shutter release, ISO 100-400, f8/16,18-55mm set at 18, focus at green line (inf). Press and hold shutter release button for 15-20 seconds then release. Repeat until you actually catch a bolt, you can spend a lot of time and shutter actuations to get a few keeper shots this way. Still the best way to acomplish lightening photos at night. Daytime same basic setup applies but you need a polarisor filter to cut down on the light. jim
camera, focus, lightning, pentax help, photography, shots
Shooting Lightning with Focus Trap kari Photographic Technique 9 08-10-2010 06:23 PM
Night lightning dandog Post Your Photos! 21 03-12-2010 01:06 PM
Lightning! Mister E Post Your Photos! 15 07-19-2009 06:37 PM
Shooting the photographer shooting my sons engagement photos skinja Post Your Photos! 13 07-04-2008 12:14 PM
Shooting lightning? Geekybiker Photographic Technique 33 06-25-2008 12:24 PM
All times are GMT -7. The time now is 07:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
