Originally posted by Andi Lo I know it was probably worth way more back then due to inflation, but it's interesting that these lenses haven't changed all that much in dollar value in the used market while some zooms have plummeted
Part of the issue there is that quality primes remain much the same, whereas zooms had a lot of fad factor: right about the time when they started getting em more or less *right,* all the R&D went into making em cheaper, smaller, lighter, slower and/or variable aperture, rather than improving them as lenses. By the time Pentax came out with the A series specs we now kinda need, this window was almost closed, actually. But you can still get the glass if you can hack the metering. with the ol' Mk 1 eyeball.
The rationale was that with people presumably using auto exposure all the time, who cared if they were a little slower or variable aperture, which seems a trend that's only gotten worse. In the 80's you couldn't have *paid* me to use an F4-5.6 lens. Now you can have one that does an OK job and doesn't make you suffer too much in the finder.
What this means is that a lot of the zooms from the days of the best build quality were primitive, and a lot of the zooms of more advanced optical design were built for consumer convenience and are no longer anything snazzy. There's this window in there, though, where they made a lot of good stuff. The fact that they were made by the metric s-load means they're still pretty cheap. But there's a lot of stuff out there that isn't impressing anyone and few know the difference anymore. May as well ask what ordinary 80's motorcycle you should buy.
