08-25-2009, 05:23 AM   #1
Filters
I'm deciding whether I can use a UV filter all the time. But what about a Polarising filter? Can that be used all the time?
John
08-25-2009, 05:32 AM   #2
Ash
Community Manager
Ash's Avatar
John,
You can use any filter any time on any of your lenses.
Are you concerned about degrading image quality, and hence are asking the question?
If so, keeping with the higher end multi-coated variety of filters ensures you minimise this risk.
Whether you should or not is really up to you - for protection (UV/Haze) or effect (CPL/ND/Grad, etc).
I keep my CPL on my 12-24 all the time, serving as both protection and polariser for my landscape shots - I then just take it off for indoor shoots if necessary.
Check out these previous threads:
https://www.pentaxforums.com/forums/general-photography-techniques-styles/335...ur-lenses.html
https://www.pentaxforums.com/forums/general-photography-techniques-styles/594...questions.html
https://www.pentaxforums.com/forums/general-photography-techniques-styles/517...g-filters.html
https://www.pentaxforums.com/forums/general-photography-techniques-styles/36581-uv-filters.html
https://www.pentaxforums.com/forums/general-photography-techniques-styles/346...g-filters.html
https://www.pentaxforums.com/forums/general-photography-techniques-styles/299...got-proof.html
And there are many more... as you can see this has been extensively discussed...
Hope this helps.
08-25-2009, 12:35 PM   #3
Marc Sabatella's Avatar
A UV is designed to be used all the time - which is to say, it provides no optical advantage ever, but hopefully only a little degradation that you trade against the feeling your lenses are "protected" in some way. A polarizing filter is designed to be used for the specific effect it achieves. Most of the time you wouldn't want that effect, nor would you want the stop or so penalty in light transmission that comes with it.
08-25-2009, 10:27 PM   #4
WheresWaldo's Avatar
Marc, if you are looking to a filter to protect the lens wouldn't a clear filter be better than a UV? Advantages of a clear, sometimes called a protection filter over a UV are:
  • They are usually cheaper
  • They are usually clear and add no color cast
  • They do not interfere with the UV filter already incorporated into the sensor
There could be more but I am too tired to think of them at the moment.
Something like this one, HOYA FILTERS - PROTECTOR rather than this one, HOYA FILTERS - UV
08-25-2009, 10:41 PM   #5
Damn Brit
Guest
Moved to Beginners Corner, a filter is not a DSLR.
08-25-2009, 10:47 PM   #6
Igilligan
Guest
You dont need no schoolin'
QuoteOriginally posted by Damn Brit Quote
"A filter is not a DSLR" you got the first chapter dialed already, you can phone it in.
I am so glad I am not in striking distance right now!
08-25-2009, 10:54 PM   #7
Damn Brit
Guest
QuoteOriginally posted by Igilligan Quote
Next week I'll explain to you how to remove a telezoom from your arse Gus.
Welcome to the forum John, don't mind us.
08-26-2009, 11:07 AM   #8
QuoteOriginally posted by WheresWaldo Quote
Sounds good in theory. Is this actually true in practice?
08-26-2009, 04:09 PM   #9
Wheatfield's Avatar
Pretty much all glass has some UV filtering properties. The rare earth glass used in some lens elements (I think they are called low dispersion) may be more UV transparent, but the average glass filter isn't made of that type of glass.
I saw a chart with the transmissive properties of various glass types a few years ago and was quite surprised by how little difference there was between a UV filter and a plain glass one.
Having said that, there is no way in the world a UV filter will "interfere" with the sensor filter. If some UV light is removed at the front of the lens, there is just less UV light for the sensor filter to absorb/reflect.
I'm firmly in the no filter unless it is going to do something category. I don't use "protective" filters. I see no reason for their existence. They add the potential for flare, they have the potential to reduce sharpness and contrast, and in return they provide little, if any, tangible benefit.
I'm pretty sure they were invented by P.T. Barnum.
08-26-2009, 06:53 PM   #10
Ratmagiclady's Avatar
They made more sense at earlier times, it seems, before lens coatings were all that fancy: I think the deal is that the UV protection doesn't hurt anything and sometimes helps, when people are trying to take their scenic shots.
My philosophy on them is that they go on lenses which are particularly vulnerable to scratches, (generally wides which have shorter hoods: I use rigid lens hoods for protection, for the most part,) and sometimes on teles which might potentially actually be shooting through a lot of haze or be used in the crap or in salt spray.
Also, my favorite lens for dealing with small children not only is one of the ones with kind of a vulnerable front element, (A 35-105 for my old Canons like the Pentax A version, ) ...is apparently just that cool to look at that said little kids want to touch it. They're astoundingly good at it. You look over at their parent, and next thing you know... It's a lot more convenient sometimes to let em do that, get it out of their system, and unscrew a filter.
08-26-2009, 07:09 PM   #11
I am not advocating the use of any filters. I too am in the camp of filter for a purpose. But nearly every filter manufacturer is pushing these protector filters as the next big thing in lens protection.
08-26-2009, 08:05 PM   #12
Yeah, but maybe that's because too many people on to them regarding the UV filters, so their looking for a new hook. I don't know; maybe I'm overly cynical. I agree that UV filters probably made more sense before lenses themselves had good coatings, so I don't think the whole idea *started* as a scam.
08-26-2009, 08:16 PM   #13
larryinlc's Avatar
When I dropped my camera with my Sigma 70mm macro attached, I had a UV filter for protection only. By total luck, the lens corner hit the ground right at the filter. The filter was destroyed...glass broken and filter ring bent beyond repair. No problem. I simply removed the filter and replaced it with a new one. No damage to the lens itself. I will swear by them. Or at least when they land just right.
Larry
camera, filter, pentax help, photography, time
For Sale - Sold: Trade: My 77mm filters for your 72mm filters (CONUS) loveisageless Sold Items 0 10-02-2010 12:29 AM
To use UV filters or Not to use UV filters?HELP NEEDED Softsoap Pentax SLR Lens Discussion 6 02-20-2010 04:50 PM
Filters? skamalpreet Troubleshooting and Beginner Help 17 07-23-2009 03:50 AM
What Filters? chipchops123 Troubleshooting and Beginner Help 5 02-06-2009 11:13 PM
All times are GMT -7. The time now is 11:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
