08-26-2009, 02:46 AM   #1
trishytee's Avatar
Shooting in raw
A second problem. I had been shooting in RAW and opening up in PS Bridge. Loved it, but recently when I use the black slider all the black goes electric blue? I was using this slider to darken my black back drop, but now cannot use it due to the aforementioned problem. Has any one else had this prob, and if so, can it be fixed??
08-26-2009, 03:51 AM   #2
pschlute's Avatar
I think you will find the blue is a "clipping" warning that will not be present on the processed picture.
08-26-2009, 03:52 AM   #3
Sorry but I do all my darkroom stuff on the highly advanced program of Iphoto. :-) Have you tried the help section of PS or even Googled your query?. Let me know the result as black is not electric blue (nice colour though !) David
08-26-2009, 04:21 AM   #4
Indeed.
The bright blue shows that the levels are too low - it is only a preview.
Clipped highlights are represented in red. If you want to turn this off, click on either of the small triangles which are at each side of the histogram in the top right hand side of the screen.
08-26-2009, 07:16 AM   #5
QuoteOriginally posted by trishytee Quote
...recently when I use the black slider all the black goes electric blue? I was using this slider to darken my black back drop, but now cannot use it due to the aforementioned problem.
This is not a problem. This is a feature that highlights the areas of the picture that are 100% black. There should be a pair of widgets in the histogram that turn this on and off for blacks and for whites.
08-26-2009, 07:20 AM   #6
Nass's Avatar
click on the little arrow at the topleft of the histogram
08-26-2009, 10:40 AM   #7
PEG Moderator
Kerrowdown's Avatar
Well that sounds like it's sorted.
Some cracking advice here and fast too.
08-27-2009, 05:29 AM   #8
trishytee's Avatar
Thank you thank you!!! No one here knew what I was talking about. Thanks Nass for emplaining how, who knew what a widget was????
Wheeee!
camera, pentax help, photography, slider
K-x shooting in raw wingman Troubleshooting and Beginner Help 5 06-14-2010 10:55 AM
Are you also shooting raw ONLY? D0ri Photographic Technique 51 06-03-2010 12:01 PM
Shooting Raw Gregor Troubleshooting and Beginner Help 13 02-16-2010 11:03 AM
shooting RAW AmandaJL Pentax DSLR Discussion 14 01-15-2008 09:22 PM
Shooting in raw hmcfly Photographic Technique 16 05-30-2007 07:32 AM
All times are GMT -7. The time now is 09:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
