Originally posted by blackcloudbrew Oh boy. I sure want to see how this get's answered. Been thinking to try this myself.
I'd only ask if you'd tried the menu reset functions, as in returning menus back to default settings.
I have not reset the menu to default settings. I am giving it a little time to try and figure out what is going on, so I can understand. In the end, though, I will reset to defaults and if that doesn't fix things than that would really stink.
Originally posted by Wheatfield Just a wild guess, but I'm wondering if the problem isn't your test bed. The AF sensor is seeing a much bigger part of the screen than what the indicator light sees.
That is a very good point. I thought that could be a problem, so I then started taking pictures of some paving stones in the backyard. They are 1 ft by 1 ft patio stones that are very textured. I took shots of those at roughly 45 degrees aiming at the seem between two stones. The same focusing behavior was demonstrated clearly.
On another note, I have been using center point focusing for all the test shots.
