08-30-2009, 12:34 AM   #1
LeDave's Avatar
Need help with Metz 48 and K2000
Hi, I am trying to experience using wireless flash. I set the flash mode on my K2000 to wireless and it says CH.1. I turn on my Metz 48 AF-1 flash and try messing around with it while it is not attached to my camera, I can't seem to find a way for my Metz 48 to fire.
08-30-2009, 01:47 AM   #2
imtheguy's Avatar
You are at least half way there but it does not sound like you have familiarized yourself sufficiently with the Metz. Using the controls is not intuitive and you will have to read the manual a couple of times. Basically it involves pushing the (+) and (-) buttons at the same time to get to wireless (SLave) mode when "SL" appears in in the window with the word "OFF under it. Press the (+) button and it will turn "ON". When all the blinking stops after 10 sec or so, it will show the channel and #1 is the default. If not, follow the manual for initial channel setup and come back to the thread if that has a problem. I found it unfriendly to set up but once done it has worked flawlessly since.
Don't forget about the camera menu item to enable/disable on-board flash during wireless controll so you can have the on-board flash communicate to the Metz then shut down just before the shutter opens instead of flashing if you want.
camera, flash, k2000, metz, pentax help, photography
Wanted - Acquired: Metz 48 Af-1 or Metz 58 AF-1 flash for Pentax jstingo Sold Items 0 07-14-2010 04:07 AM
Metz 58 wireless not working? Metz 48 works great? Ideas? ksignorini Flashes, Lighting, and Studio 6 02-07-2010 05:33 PM
New K2000 sherib Troubleshooting and Beginner Help 13 06-08-2009 08:34 AM
Is the Metz 58 AF-1 Flash Compatible with K2000/KM? lawsonstone Pentax DSLR Discussion 3 06-07-2009 02:05 AM
All times are GMT -7. The time now is 09:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
