09-03-2009, 06:54 PM   #1
*istD help needed
Hello,
I'm new to the forum and actually only found this when looking for some help with my *istD. I'm on vacation with the family and it died on me.
At first when we tried to take a picture, the shutter would open, but then it would not close. We had to turn it off to try and reset it. Now it turns on but can'
t take a picture at all. It does not appear to be reading the memory card at all either. I'm not getting a reading on LCD with regards to the memory card anymore. If I try to take a picture, it does nothing.
Any help or direction would be appreciated!
Thanks
09-03-2009, 09:43 PM   #2
Damn Brit
Guest
Hi Steve, first thing to try is new batteries. Try that and get back to us.
09-04-2009, 07:28 AM   #3
MJB DIGITAL's Avatar
that was my first thought too.
my ist*D will start machine gunning when the batteries are low. i hate that
09-04-2009, 07:40 AM   #4
Ash
Community Manager
Ash's Avatar
Welcome here Steve.
As above, then try on a different lens and see as well.
09-05-2009, 05:53 AM   #5
eccs19's Avatar
I had the same issue with my *ist D, plus many other strange things were going on. I ended up changing the small battery in the bottom of the camera, and haven't had an issue since. Hope this helps you out as well as it did me.
09-05-2009, 07:02 PM   #6
Sounds good! We had just replaced the batteries, but maybe there is an issue with them. I will pick up another set and let you know!
Thanks again.
09-09-2009, 04:30 PM   #7
OK... tried new batteries with no luck. The indicator for dead batteries was coming up from a brand new set. Anything else I can try? I'm guessing not...
09-10-2009, 12:02 PM   #8
eccs19's Avatar
QuoteOriginally posted by russett Quote
Did you try replacing the small battery in the bottom of the camera as I previously suggested? It solved a lot of issues with my camera.
09-12-2009, 06:11 AM   #9
The little battery on the bottom has been changed as well.
Current status:
It turns on. It will sometimes be able to focus and start to take a picture, but the shutter won't release until i turn off the camera.
Other times, it will not start to take a picture at all. The shutter won't respond. The auto focus will not respond.
We have changed the main batteries, the small bottom battery, lenses and Mem. Cards.
Anything else I can try at home?
We were in Florida with some crazy hot days when this all started. Could that have anything to do with it?
Thanks
09-12-2009, 07:37 AM   #10
Ash
Community Manager
Ash's Avatar
Doesn't sound good - unless the new batteries were also not powerful enough to give juice to the camera. They were Lithiums or high-end NiMh rechargeables I presume?
Any different with another lens fitted?
Not sure if the weather has much to do with it.
Failing all this, it may need to be looked at by a repairer...
*istd, camera, card, help, memory, pentax help, photography, picture
*istD vs K7 eccs19 Pentax DSLR Discussion 10 09-11-2010 02:47 PM
*istD? Classic_Obsession Pentax DSLR Discussion 21 07-01-2010 10:02 PM
What would be an upgrade for a *istD? DavidF Pentax DSLR Discussion 10 11-22-2009 11:33 PM
*istD / IR Billgscott Pentax DSLR Discussion 3 02-25-2009 06:17 PM
istD or DS kibipod Pentax DSLR Discussion 9 11-20-2008 02:53 PM
All times are GMT -7. The time now is 04:45 AM. | See also: NikonForums.com, part of our network of photo forums!
