Originally posted by paulelescoces The 50-135 does have an enormous hood... I also try and keep it mounted whenever practical...
I do find a need to remove it when shooting flash reasonably close (otherwise get a strong shadow on the lower side of the image)...
Paul
a lot of hoods will cause shadows with a flash, even smaller ones. thats the only time I can recommend not using one. there is no good solution with this lens im afraid. with a smaller prime lens, the hood can be used always and be like it isn't even there, or a part of the lens. for you... well I guess you will have to decide whether or not is worth using in most situations.
