09-06-2009, 10:50 AM   #1
esman7's Avatar
Lens hood - when is it necessary?
Is the purpose of the hood to prevent vignetting? Are there certain situations I should keep it on?
Some reviews say that using the hood will help sharpen the image. I don't understand the mechanics of it, but on my DA* 50-135, is it worth keeping on at all times, or only in very bright situations?
Thanks.
09-06-2009, 11:01 AM   #2
Banned
the purpose of the hood is to help reduce stray light from entering the lens and causing flare and loss of contrast. the added contrast from using a hood gives the appearance of a sharper image. I don't have the 50-135 so I don't know the size of the hood, however I would say that unless its a nuisance in some manner or prohibitive to your photography there is no reason to not use it. its like the old saying "cheap insurance". it can also serve as protection for the lens (particularly the front element) in certain situations. I use a hood on all of my lenses and fail to see why one wouldn't use a hood if one has one to use.
09-06-2009, 11:12 AM   #3
esman7's Avatar
The hood is pretty long, and I get a lot of stares (good ones!) - but because it's a faster lens and if I use it indoors (ie. in an indoor market, with some ambient exterior light entering), would it still be best to use a hood?
09-06-2009, 11:20 AM   #4
Banned
QuoteOriginally posted by esman7 Quote
it wouldn't hurt. if there is not much of a chance of strong stray light causing flare (in the situation you described, the SMC coating should be more than enough) then sure, you wont need it. but you will never encounter a situation in which the hood will cause vignetting or loss of light. (that I am aware of) its designed to block stray light only, so even in darker situations it will cause you no trouble. you can flip the hood around backwards to "store" it on the lens correct? I know this is typical of most bayonet mounted hoods. thats what I would do in your situation if you are getting more looks than you'd like. its really a common sense thing, if you feel there is a chance for strong flare, or may need the protection of the front element that the hood can provide, use it. if not, don't. I only use primes (my only zoom has a built in hood) and the hoods for my lenses screw on and are rather small, so they are always on.
09-06-2009, 11:26 AM   #5
esman7's Avatar
Guess I'll just keep it on then if it can't hurt.
Thanks for your help.
09-06-2009, 11:29 AM   #6
Banned
not sure how much I helped, but no problem.
09-06-2009, 11:35 AM   #7
Damn Brit
Guest
In a confined space like an indoor market, the hood will be serving primarily as protection.
09-06-2009, 11:41 AM   #8
Banned
QuoteOriginally posted by Damn Brit Quote
or as a convienent means of bumping into everyone and having to deal with a lot of people giving you dumb looks for annoying them with your oversized and pretentious equipment.
09-06-2009, 12:22 PM   #9
Damn Brit
Guest
QuoteOriginally posted by séamuis Quote
that's a cross we have to bear.
09-06-2009, 01:32 PM   #10
Would the same apply at an indoor concert at night? Or is that a time when you're better off getting all the light you can get?
09-06-2009, 01:36 PM   #11
PEG Moderator
Kerrowdown's Avatar
For me, all the time, all lenses for all the reasons above.
09-06-2009, 02:10 PM   #12
Ash
Community Manager
Ash's Avatar
QuoteOriginally posted by betamax Quote
Photography is not about gathering all the light you can get, it's about selecting the light you want to gather. What you don't want (most of the time) is flare - it can ruin perfectly good images. There's no good reason not to have a hood on in any situation.
09-06-2009, 04:12 PM   #13
esman7's Avatar
would you then reccomend hoods for lenses that don't come with them? Ie. 50mm FA 1.4?
09-06-2009, 06:18 PM   #14
esman7's Avatar
Btw, just took my camera out and it was raining... lens hood saves my ass as it protected drops from hitting the front element.
Of course a k200d w/ bg3 and a DA* 50-135mm - one fully weatherproofed package... way to go Pentax
Just from this aft:
09-06-2009, 06:54 PM   #15
dadipentak's Avatar
Deep.
Truth.
camera, hood, lens hood, pentax help, photography, situations
For Sale - Sold: Pentax Rectangular Metal Lens hood for 58mm Lens (Worldwide) oneill Sold Items 2 03-19-2010 05:12 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 03:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
