If the camera's mount contacts are not all shorted out by the lens base, the camera does not recognize that you have a manual aperture lens mounted. I bet that if you look with the lens mounted, the mount contacts are not shorted out by the lens base. This also can happen with a lens with a painted mount.
Carefully cut a bit of aluminium foil in a curve to cover the contacts on the camera mount and while not showing in the mount "hole" be under the lens to hold it in place. That should get your Shake Reduction back.
