09-19-2009, 05:45 AM   #1
kent's Avatar
K200d taking pictures by itself
Hi there. I faced a problem using my k200d. One day I was taking some pictures of clouds and suddenly camera began taking a lot of pictures without having shutter button pressed. By the way I suppose there was much more than 2.8 frames/1 sec. I switched camera off and nothing happened. Then I opened battery door and camera just stoped. When I closed door , the mirror claped one more time and then everything was working fine but there was no picture saved I took before that rapid-fire. Could you explain me where is the problem?
09-19-2009, 10:26 AM   #2
Marc Sabatella's Avatar
If no pictures were saved, I'm guessing that what was really happening was the aperture blades were opening and closing by themselves, not anything to do with the mirror or shutter. I suppose that could happen if the lens were not quite mounted properly and the level that normally controls the blades slipped. Seems someone else described having a similar problem once; you might try browsing/searchin around for that thrad to see if anyone had any other ideas. If it doesn't happen again, I'd treat as a fluke and forget about it. Similar thing happened to me when I first tried out a lens I had bought - pressing the shutter made the aperture blades go creazy the first two pictures I tried to take. I remvoed the lens, remounted it, and have never had that problem again.
09-19-2009, 12:50 PM   #3
khardur's Avatar
strange... Only thing I can think of is - do you have a battery grip on and were you perhaps inadvertently holding down the shutter button on the battery grip? I did that once, although I wasn't pressing hard enough to release the shutter, only to have the autofocus go crazy on me...
I was simply walking along holding the camera in my hand and heard the AF running - I was thinking - "what the heck it's going crazy on me.." Then later I realized I had been putting pressure on the shutter release button that's on the grip.
09-20-2009, 12:47 AM   #4
kent's Avatar
No, I do not have battery grip. I found a thread and it seems that most of k200d users faced a problem. All of them run out of battery energy
09-20-2009, 10:30 AM   #5
Well, I'd hardly say "most" K200D user have faced this. But of course if someone starts a thread on the topic, those who *have* would be more likely to chime in an see "me too". My guess is that the folks who posted to that thread represent pretty much the *only* K200D users here who have experienced it, and the vast majority haven't. So I'd still say, if it's a one time thing, write it off as some sort of temporary glitch and don't worry about it.
09-26-2009, 09:47 AM   #6
i experienced this type of phenomenon after doing a dust removal process - never happened since
09-26-2009, 02:35 PM   #7
I think the answer is very obvious! Your camera is telling you that you are not using it sufficiently. It is demanding more use. You absolutley MUST get it out more often!!! What the heck are you doing???!!!!!
09-30-2009, 06:04 AM   #8
Stf
Hi,
I have a K200D since April this year and also experienced this. I believe this may happen when batteries are (almost) empty (I have no grip). I may be wrong but it is what I assumed anyway.
Stf
10-01-2009, 07:21 PM   #9
QuoteOriginally posted by Stf Quote
Hi,
Stf
Aha, so its an unadvertised feature. Its the Pentax Low Battery Audible Alert.
10-01-2009, 07:38 PM   #10
mtroute's Avatar
Mine did it once. A symptom of really low batteries...
camera, door, k200d, pentax help, photography, pictures
When Connected to USB taking pictures cbaytan Pentax DSLR Discussion 2 09-25-2010 02:43 PM
Please help of taking firework pictures Ken T Photographic Technique 18 12-02-2009 05:59 AM
Taking pictures of Stars on K200D Rage Photographic Technique 30 06-19-2009 08:06 AM
Taking pictures of the sunrise... Javaslinger Troubleshooting and Beginner Help 8 02-15-2009 06:18 PM
K100d- Not Taking Pictures spanky12 Pentax DSLR Discussion 4 01-29-2008 07:28 AM
All times are GMT -7. The time now is 09:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
