Originally posted by snostorm
The same advice is pertinent to shooting RAW. In my experience, there is too little difference between a properly exposed jpeg with the camera set up correctly to justify the extra post processing time and effort and the much larger file sizes, not to mention the hit in camera performance, but I shoot birds primarily, and the speed is sometimes a priority for me where it isn't for others. I take a lot more shots than most (30-40,000/season), so the PP time and storage issues are more significant for me. I also shoot with the usual end product of a print in mind. The miniscule differences revealed at 100-300% on a computer screen are largely irrelevant in even largish prints.
I'm sure many will disagree, but the point is to make these decisions for yourself,
Scott
I disagree (except for the last remark), there is too much that can go wrong and cannot be corrected with JPEG. If you can afford a $ 1300 camera, you sure can afford a 16Gb memory card.
There is little performance difference between RAW and JPG, the postprocessing can be little or no time consuming. Try Picasa from Google, it handles PEF files as easily as jpg's.
RAW will enable you to apply a different white balance (see my post on the AWB problem), gives you more dynamic range etc.
- Bert
