Hello, I can't seem to get this to work as described in the manual, maybe I'm doing it wrong?
I've attached pentax-a 50mm, changed the focus mode to AF.S and focused on a spot 50 cm away. I pressed the shutter fully and moved something into focus immediately afterwards. It beeped (ie focus confirmation beep) but the camera didn't take a picture.
Then, I picked the camera up, pressed the shutter fully, moved the camera so that something became focused, and again it beeped but didn't take a picture.
However, if I press the shutter fully repeatedly, then when the camera does have focus, it takes the picture, but it prevents a picture being taken when when it's out of focus. In other words it's functioning like the camera has to be still and focused to take the picture (ie it's acting like an instantaneous mode that says "no focus? no picture") rather than 'catching' a subject when it comes into focus?
Is this what's supposed to happen or is there something else I'm supposed to do? I was under the impression that catch-in-focus is like a standby function that'll wait until a subject is in focus then take it (if shutter has been pressed). Is there some time within which the subject has to come into focus and if so, which setting would it be to increase that time?
Many thanks
