09-30-2009, 06:29 PM   #16
Marc Sabatella's Avatar
Not sure what you mean. Pentax cameras certainly have light meters; all DSLR's do. That's the thing I said needs certainly amount of light to yield reaosnable results. The same is true of any film SLR, although it's certainly possible your Olympus was able to do this in lower light than your K2000. But what's probably more relevant is that your Olympus was probably able to meter with the lens wide open and "read" the aperture ring, thus avoiding the need to stop down to take a meter reading like your K2000 does. Pentax film cameras used to be able to "read" the aperture ring too. they removed this ability about the time they stopped putting aperture rings on the lenses. It's the same with other manufacturers; some cameras don't even allow stop down metering (what you are doing with the +/- button) so there's no way to get any meter reading with older lenses at all on those camera.
aperture, camera, k2000, k2000 manual lens, lens, light, mode, pentax help, photography, shutter
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Green Button Metering with Manual Lens zombieCat Pentax DSLR Discussion 4 02-15-2010 06:07 AM
K-7 & Metering A Cosina 50mm Manual Lens... PentaxFan Pentax DSLR Discussion 14 01-31-2010 07:23 PM
Need some help: K-m/K2000 and manual lens grishazzz Troubleshooting and Beginner Help 19 04-22-2009 04:19 PM
K2000, manual lens, and Av mode SOldBear Pentax DSLR Discussion 10 03-19-2009 09:49 AM
All times are GMT -7. The time now is 01:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
