10-13-2009, 08:04 AM   #1
Carl Zeiss Biotar 2/58mm T
I bought this lens and I was trying to take some pics using a genuine M42 Pentax PK adapter.
My problem now is that the lens keeps moving when I'm focusing or stepping down. It is such a tiny lens and it does not sit properly on the mount like any Pentax lens.
How do I fix this?
Thanks
10-13-2009, 09:44 AM   #2
Igilligan
Guest
I am assuming the CZ biotar is like the Helios 44-2 (which I believe to be a copy)
Because the base of the lens where it should hit the camera lens mount is so small, it actually rides against the M42 to K adaptor... Is that what you are seeing?
If so, the issue is the play between the adapter and the camera mount. There used to be a thread on here about slight bending the "ears" on the adaptor to tighten it a little, but I cant find it in the "search". I did not attempt to bend mine as I was afraid it would make it too tight and then it might be a pain to get off!
Mine does the same thing as yours, but it does not really cause any problems, it just feels funky.
My Helios 44M has a big base and sits directly against the Lens Mount.
camera, lens, pentax, pentax help, photography
Wanted - Acquired: Carl Zeiss Jena "T" Biotar 58mm/2 (M42) photobizzz Sold Items 0 12-12-2009 04:46 PM
Czj Biotar 58mm f/2.0 hinman Pentax SLR Lens Discussion 29 09-16-2009 07:57 PM
For Sale - Sold: Carl Zeiss 28mm/2 and Voiglander 58mm/1.4 SloPhoto Sold Items 12 03-30-2009 10:58 AM
All times are GMT -7. The time now is 06:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
