10-18-2009, 11:30 PM   #1
Fuzzy numbers in viewfinder
Hi Everyone. I just got my new K200d yesterday. While looking through the viewfinder, I noticed that the numbers at the bottom seemed to move in and out of focus, if that makes sense. They would start out fuzzy at times, and then grow crystal clear, only to go fuzzy again and so on. I also gave it to my sister and she noticed the same thing. Is this typical, or is it a defect with my camera? I have no experience with using viewfinders since this is my first dslr, so I really can't tell...
10-18-2009, 11:41 PM   #2
Damn Brit
Guest
Are you using fully charged batteries and what type are they? Not all AA's work well with DSLR's, maybe that is the problem.
10-18-2009, 11:45 PM   #3
That's interesting. I'm using eneloops, which have never been problematic for me.
10-19-2009, 12:03 AM   #4
Damn Brit
Guest
Then that's not the problem then.
Try sending a PM to this member - PentaxForums.com - View Profile: dorianb She works for Pentax and should be able to get an answer from a technician for you.
10-19-2009, 05:01 AM   #5
Mike Cash's Avatar
Have you adjusted the diopter?
10-19-2009, 07:53 AM   #6
Yes, the viewfinder looks pretty clear. It's only the numbers that are sometimes not in focus. I'm assuming this isn't a normal thing?
10-19-2009, 09:29 AM   #7
Marc Sabatella's Avatar
I've never seen it.
10-19-2009, 11:03 AM   #8
Ben_Edict's Avatar
QuoteOriginally posted by enialet Quote
You are unfortunately assuming right. Quite like Marc I never even heared about such a problem.
Ben
10-19-2009, 11:38 AM   #9
Nass's Avatar
QuoteOriginally posted by Mike Cash Quote
I had exactly the same thing once when I was out on a nightshoot and BOY did I panic that I'd broken it somehow. If fact it turned out to be just the diopter, it had shifted somehow. Subsequent investigation revealed that it got caught when I took the camera out the bag.
Enialet, are you familiar with what the diopter is? If you look through your dslr eyepiece, you should see a ridged protusion that you're able to adjust - it looks something like this. It's that ridged thingamygummy between the camera body and the rubber eyecup on that pic - this is adjustable (for people with poor eyesight) - perhaps yours is slightly loose and got shifted?
I have to say I'm having a hard time working out what else it might even be as that internal LCD isn't affected by lenses. Would a wonky mirror have such an effect?
10-19-2009, 11:50 AM   #10
Ok, I just duplicated the problem on my K200D. The diopter has to be right on the money. Or otherwise the numbers will get fuzzy with eye movement at the viewfinder.
Adjust the ridged slider on the viewfinder until it is perfectly clear while a lens is in focus.
10-19-2009, 12:12 PM   #11
Thanks everyone for the replies. I checked the diopter when I took the camera out of the box, but it didn't seem to help with the number problem (while the viefinder is crystal clear, the numbers still shift in and out of focus). From the looks of things, it seems to be a defect. I'll fiddle around with it some more tonight, then look into getting a return/exchange.
10-19-2009, 12:21 PM   #12
Be sure the lens is perfectly focused on a well lit item. Then adjust the diopter until you see the clearest, best focused view through the finder.
10-19-2009, 12:29 PM   #13
Mike Cash's Avatar
QuoteOriginally posted by wildlifephotog Quote
Or try looking at a blank white wall and adjust the diopter until the lines on the focus screen are sharp. Lens focus is irrelevant.
10-19-2009, 12:33 PM   #14
Sorry, I wrote that from my view. I don't have lines on my screen.
10-19-2009, 06:29 PM   #15
GerryL's Avatar
I don't know if this would help but here goes..
This actually happened to a friend of mine who borrowed my K100DS.
She was nearsighted.
See can see the viewfinder clearly but can't shift her focus to the numbers quickly.
She told me that the numbers seem to be focused at times and blurred at times.
She didn't even notice it till I pointed out to her how to confirm focus by looking for the green hexagon bottom of the viewfinder screen together with the numbers.
She said..oh yeah, I didn't even notice there was information there..then she experience the varying focus (only of the numbers though).
camera, pentax help, photography, viewfinder
Macro Some bugs and a fuzzy flower the swede Post Your Photos! 3 08-06-2010 02:04 AM
K7 fuzzy images bisjack Pentax DSLR Discussion 11 10-28-2009 01:27 PM
Fuzzy Rednecks Venturi Post Your Photos! 8 10-04-2008 10:50 AM
Fuzzy Corkscrews... heliphoto Post Your Photos! 13 09-11-2008 09:56 PM
a few fuzzy portraits hamidlmt Post Your Photos! 6 07-31-2007 03:23 AM
All times are GMT -7. The time now is 08:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
