10-25-2009, 07:53 PM   #1
Yet another manual lens question!
I've tried to find the answer to this question before posting, but have not been able to find it addressed.
I recently purchased a 50mm f2 lens on ebay for $10, which I was pretty sure was a darn good deal! I've had a lot of fun with it this week, but also a little frustration. I've read the instructions on how to use manual lenses and have gone through all the steps. I have the K2000, so in manual mode the +/- button stops down the lens and chooses the correct shutter speed. It also seems to work in the Av mode by choosing the shutter speed. My question is this: how would I adjust to a higher shutter speed if the camera automatically chooses this?
Thanks for any and all answers.
Sheri
10-25-2009, 07:57 PM   #2
Eruditass's Avatar
To choose a higher shutter speed than what is given, you need to up the ISO or lower EV Comp.
10-25-2009, 08:06 PM   #3
Marc Sabatella's Avatar
QuoteOriginally posted by sherib Quote
Yes, but only wide open - the aperture ring is completely ignored in Av mode. So Av mode will only shoot your 50/2 at f/2, regardless of where you set the aperture ring.
Same way you would with a "regular" lens. In M mode, the dial controls shutter speed directly; in Av mode, you can dial in exposure compensation to increase or decrease shutter speed (and thereby alter exposure). Or change ISO or aperture (M mode only) and then let the camera pick a new shutter speed for you.
10-28-2009, 06:50 PM   #4
Stratman's Avatar
QuoteOriginally posted by Eruditass Quote
Or use a lower ( more open ) aperture.
10-28-2009, 07:00 PM   #5
Barnster's Avatar
Use your M Mode.M stands for manual,which in that mode,you can adjust the shutter speed and by using your aperture ring on your lens adjust the aperture.combine to get the right combination.
camera, lens, mode, pentax help, photography, question, shutter
Manual lens question pdxbmw Pentax DSLR Discussion 9 10-18-2010 04:52 PM
new k-x came! shots with manual lens + question acrollet Pentax DSLR Discussion 4 12-09-2009 09:24 PM
manual lens focus question kjfaust Pentax DSLR Discussion 11 05-16-2008 05:20 PM
SR on a manual lens question GatorPentax Pentax SLR Lens Discussion 1 04-17-2008 01:10 PM
Question about using manual focus lens. XMACHINA Photographic Technique 3 02-13-2008 08:23 AM
All times are GMT -7. The time now is 01:43 PM. | See also: NikonForums.com, part of our network of photo forums!
