Originally posted by HeG I heard the other day, that the camera (k20d) not reset all settings in the camera, when using reset-function(s)? If you donīt send the camera for maintenance/service.
I heard it when I was going to borrow a personīs camera and he was so affraid that my settings (that I maby put in the camera) will stay for ever in the camera, and that the person can not change my settings back to his...
Sounds like you or he is confusing two different things. The reset function *does* reset all settings back to the default - as in, the factory defaults the camera was set with. It doens't return the settings to however he happened to have it set up. So if you borrow the camera and change settings, it's true there is no magic button to push that will just automatically restore all things to how he had them - the reset button will undo *his* settings too. But of course, it's ridiculous to think that this means he can't get his settings back. He'd just have to remember / write down what his settings were, and check them all individually after getting the camera back. Or make you promise not touch the Menu button, so you don't change any settings.
