Assuming this is a K-mount lens not a screwmount lens with an adapter, the lens aperture should have stayed wide open when mounting. But if the lens is defective, or something got caught up when you mounted it, it's possible the aperture blades closed down. If there is an aperture ring and it has an "A" position, you should use that, as another poster mentions. If it doesn't have an "A" position, it should still stay wide open when mounted even if the aperture ring is somewhere else. But test this with the lens off the camera - move the aperture ring and see if the aperture blades close, also play with the lever sticking out the back to be sure it opens and closes the blades when the aperture is not set wide open (eg, when not set to the smallest number on the ring).
