11-01-2009, 06:18 PM   #1
iht's Avatar
Spotmatic SP Battery?
Hi everyone,
I just got a Spotmatic SP without a battery.
I did some research on the net, but got confused after seeing various posts about the requirement for a mercury type battery that is no longer in production.
I also notice the batteries for my KX don't fit the slot.
Can anyone please advise just exactly what battery types are compatible with this camera? Are they readily available? This will be much appreciated.
Thanks a lot.
11-01-2009, 07:13 PM   #2
iht
iht's Avatar
Ah, I found the link here:
http://www.google.com.au/url?sa=t&source=web&ct=res&cd=1&ved=0CAoQFjAA&url=h...dPq5bV5mxBMDyg
This answers the question. Sorry for asking this here and thanks.
11-01-2009, 07:16 PM   #3
monochrome's Avatar
QuoteOriginally posted by iht Quote
Hi everyone,
Thanks a lot.
According to Pentax-manuals.com the Spotmatic SP500 and SP1000 used a Mallory PX400 1.35V Mercury Cell. Wein and Excell make Zinc/Air 1.35V replacements (but they only last about 2 months and are $5 - $10 each). Here is one source for the batteries.
The Silver Oxide replacement is a 1.5V Excell battery #S400PX. Spotmatic cameras have a bridge circuit that adjusts to the higher voltage so the meter stays accurate (I believe this is true of the Spotmatic SP series).
Here's a pretty detailed article from OK1000PentaxBlog
11-01-2009, 08:02 PM   #4
iht
iht's Avatar
Thanks very much for your info monochrome.
11-03-2009, 01:56 AM   #5
iht
iht's Avatar
OK, found an AG3 pack just for a quick test (the guide says any type 392 will do, of which the AG3 is one). I couldn't get the needle to turn when pressing the meter switch...
I've tried both polarities - no response from the camera. The battery seems to be very small given the size of the slot. I've measured the battery using a multimeter, and it's definitely discharging properly.
Anyway, I found another LR44 battery lying around, so I tried putting it in. The needle moves when pressing the switch! Although it does not give the correct reading.
Any advice? Thanks a lot!
battery, camera, pentax help, photography, sp, spotmatic, spotmatic sp
Spotmatic F battery question zoltan1983snapper Pentax Film SLR Discussion 33 06-11-2020 09:24 PM
Yes! My Spotmatic F will take a LR44/357 silver oxide battery Tom in Delaware Pentax Film SLR Discussion 6 04-30-2010 05:53 PM
Battery for Spotmatic SPII? Brianog Pentax Film SLR Discussion 10 01-03-2009 09:20 PM
Spotmatic (not SpotII, not SpotF) Battery john carter Pentax Film SLR Discussion 10 01-27-2008 08:33 PM
All times are GMT -7. The time now is 10:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
