Thank you so much to those who have responded. I very much appreciate the help!
Originally posted by K McCall First, can you answer some questions for us? Do you use the Auto focus, the center-spot focus, or the "user-selectable" focus points? If you use center, do you focus-recompose?
I generally tend, when using an AF setting, to use a center focus, and then focus recompose. As of late, I've been using a manual 50mm pretty regularly, so I am focusing manually quite regularly as well.
In fact, I primarily prefer shooting in manual everything lately, as it gets me what I want more often than letting the camera have any control.
Originally posted by clmonk K McCall asked the right questions. Tell us how you are doing it now and it will be easier to direct you on how to correct your mistakes. BTW #3 looks right to me! Keep in mind, the larger the aperture (smaller f number) the more narrow the depth of field. On the picture of the dog, for instance, only a small portion of the dog would be in perfect focus.
Thank you. #3 is actually not as good SOOC as it appears. I thought I had posted the SOOC, but that one has had an unsharp mask layer applied to the eyes--you can see the lashes are pretty soft--it seems the focus really hit near the collar of her coat.
Originally posted by Rondec Focus is often a tough thing. I think your last photo is a great photo! The hard thing with kids and animals is that they are moving. This often makes it look like you didn't focus well, but the reality is they just moved out of your plane of focus. The problem with your idea of shooting at f22 is that then your shutter speed goes down to the place that you will have a lot of motion blur.
Yes, I don't think I could ever *really* shoot in f22. The loss of bokeh would make me batty. And since my entire photographic portfolio consists almost entirely of pets and my own kids, I know all too well how fast they are. Maybe I'll just have to resort to f16 and the dreaded on camera flash...or just buy a P&S
Thank you for the compliment on the last photo as well. It's one of my faves, but mostly because of the subject.
Originally posted by Marc Sabatella Assuming MF: know the viewfinder lies to you about the DOF at very large apertures. It shows too much in focus below about f/2.8. So it will always be the case that some things will look into focus but turn out not to be. I recommend practicing focusing on a printed page, learning how to anticipate which parts of what appears to be in focus will really turn out to be.
Assuming AF: the focus points are much larger than the red dots in the viewfinder. So it's impossible to place the focus *exactly* where you want. When that level of precision is required, you may need to switch to MF - but then, see above.
Thank you...this makes some definite sense, though I do tend to have problems past 2.8. The first and 3rd photos were taken at ~100 and 300mm respectively, and so....I think about f5.6--am I going to run into the same problem at higher f-stops if I am also shooting at longer focal lengths?
I've also been practicing a lot lately in MF on still things (like sleeping babies instead of waking ones) because I have noticed the problem and I do wonder if it isn't just my eyesight worsening. It gives me hope to know that I really am seeing more in focus on the viewfinder than is actually there. BEcause it often seems that the focus is a little below and to the right of my actual desired point of focus...should I assume that there is some sort of "sweet spot" there? Will print tests show a consistent spot where the actual focus plane is correct?
