11-11-2009, 02:06 AM   #1
possible problem with my new K-x (other than batteries)
Well, I got my K-x (black unfortunately)and tried testing it a bit.
unfortunately so far none of my batteries work - and i have a few dozen rechargeable batteries among them quite a few recently purchased eneloop re-badges.
However I can feel/hear the mirror or shutter or sensor assembly shifting when I tilt it a little, like those cylindrical cow sound toys.....
Also, if i go to live view , before the camera shuts off, the autofocus makes a lot more noise than usual. I also hear a lot of noise from the shutter i think, a grating sound and very loud.
It would seem like I'll have to return it.
11-11-2009, 06:50 AM   #2
same here
Identical observations regarding shutter/sensor movement ... doesn't appear to be a problem but i'd like an explanation.
Similar Live view/shutoff observations ... i think its the mirror ... heck of a vibration too!
Batteries - are now a minor irritation for me ... I had to learn to be patient and leave the batteries in the camera for a while before turning it on. Battery issue solved! Weird, it was only the first time. Prior to this I tried a number of different batteries with no success. Now some of these same batteries work if I install them and wait...
11-11-2009, 08:42 AM   #3
tomtor's Avatar
No worries, all the sounds you describe are the free floating SR mechanism, either idle or in action.
Every body has it.
Move the front switch to MF and disable sr and the lv sounds should be almost absent.
11-11-2009, 08:54 AM   #4
causey's Avatar
People have asked the same questions about the previous models (K200d, K20d)--you can check the old threads with the 'search' function: as tomtor said, the sound comes from the SR system.
11-11-2009, 02:55 PM   #5
that helped, turning offf the SR. Didnt know the k20 did it too, the one I have (and k10) don't do it.
Even leaving the batteries for a day doesnt change a thing.
11-11-2009, 03:19 PM   #6
K-7 has similar "problem."
Read this thread
11-11-2009, 07:34 PM   #7
pbo
pbo's Avatar
K10D "don't do it" because it has no LV or video. You can check that it does same thing by, say, setting camera to M mode and setting shutter speed to 4-8 seconds. When shutter is open, you'll hear quite an audible whirring sound.
11-11-2009, 08:04 PM   #8
QuoteOriginally posted by pbo Quote
I was not very clear; in addition to less noise by turning the SR off, I stopped feeling/hearing the sensor moving as well when I move it around.
It's good to know that it's normal, though it's annoying. Too bad non of my batteries so far work.
11-11-2009, 08:11 PM   #9
pbo
pbo's Avatar
Well, that's the price we pay for a steady LV finder.
Weird... All my rechargeables work in k-x. Though, the first time I tried Ni-Mh's (eneloops) in K-x, I had to wait about half a minute before it powered up. After that first time, all NiMh's start up much faster.
11-11-2009, 08:28 PM   #10
Marc Sabatella's Avatar
QuoteOriginally posted by davidvcd Quote
True. But the K10D *does* make the noise when you move the camera around. The weather sealing might have softened the sound some, but it's there - it's there in all cameras with SR.
Have you followed the instructions in the various threads here involving making sure to set the battery type correctly, waiting a while before the turning the camera on, etc?
11-11-2009, 10:04 PM   #11
1- With my K10, whether the SR is on or off, on the camera is on of of, I hear no sound of something shifting moving from the body itself like i do with the Kx. Same with the k20 and the one time I handled the K7 in store.
2- tried all the various ways, nothing works beyond a few shots. The worse is when I set it to NiMH (half the time won't turn on). I've waited more than a while before turning on the camera as well.
serial starts 3434, which seems to be one of the batches that have problems.
Luckily I was hoping that by buying through best buy, that if there was a problem it would be a simple matter to return it.
11-11-2009, 11:34 PM   #12
pbo
pbo's Avatar
Mine is 3431.... No problems so far. Hope you have better luck with replacement! I bought mine from Adorama, it has (or at least had, not sure how it is now) the body only on ebay for 550 or so, with bing 8%, that goes down to 500 or so. Free shipping, or add $10 for 2nd day air!
11-12-2009, 07:29 AM   #13
it's up to 600 now.
11-12-2009, 03:43 PM   #14
As I said, the weather sealing may make it quieter, but if the sound isn't there, then your SR system is broken. SR on *all* Pentax DSLR models involves letting the sensor float freely, and *all* models there make the noise. Listen more carefully, or hand it to someone with keener ears, and I'll bet you'll notice it after all.
batteries, camera, k-x, lot, noise, pentax help, photography, shutter, sound
Batteries problem with K200D cyberjunkie Pentax DSLR Discussion 28 06-08-2013 01:05 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 & K-5 II 39 11-03-2010 06:02 PM
Problem with Ni-MH rechargable batteries in K200D/K-M dncraker Pentax Camera and Field Accessories 5 03-11-2009 10:45 AM
Pentax K100D Batteries problem menta Pentax DSLR Discussion 106 05-04-2008 12:52 AM
Problem - K100 with new batteries - click click click. jsundin Pentax DSLR Discussion 13 08-28-2007 02:09 PM
All times are GMT -7. The time now is 06:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
