Originally posted by Jonson PL Good link - I use that site for lens info a lot, but never think of it for info on bodies. I tend to just look at the announcement, preview, or review on dpreview.
Quote: Iso 1600 might look a little cleaner on the K200. Depends how old the model K10 is.
The reputation of the K10D for having sub-par high ISO is based on several factors, some of which did apparently improve over the life of the product (ie, late models better than earlier). But apparently, the main source of the difference is that the K10D achieves high ISO through its 22-bit ADC - a very unusual approach - whereas the K200D is more like other cameras and uses an analog amplifier in front of a standard lower-bit-count ADC.
Anyhow, I haven't been able to compare directly, but most people who have done direct comparisons report the K10D is *worse* than the 6MP cameras for high ISO noise, but the K200D is in my own tests (and those of others) *better* than the 6MP cameras.
Realistically, that's the only out-and-out advantage of the k200D over the K10D. If you happen to prefer smaller/lighter cameras and/or AA batteries, those are also advantages for the K200D. But in pretty much all other respects, the K10D is the better camera - better viewfinder, larger buffer, more controls, etc.
Still, for the way I use the camera, none of the extra buttons or dials of the K10D would have much value to me. I don't ever change metering mode, or AF point selection mode, or any of the other things the K10D makes easier. With one exception - changing ISO. The OK-button-plus-wheel method of the K10D is really only thing I still envy, but I tend to to just change ISO when entering or leaving building, so even that is no big deal to me.
