11-19-2009, 12:45 PM   #1
Pentax K100 Super flash question
Is it possible to use true manual flash on the K100 Super, that is, have the flash work at full capacity NOT dependent on the camera-to-subject distance of the amount of light reflected back to the sensor.
It seems to me that the flash is actually AUTO whether it's set to auto or manual, that is, flash exposure is determined by the amount of light reflected back to the sensor.
I hope this is clear.
Thanks,
Pentaxable
11-19-2009, 12:52 PM   #2
My camera is K10D and I've never used the K100D Super. But I don't think they are any different related to your question.
In fact, your question is not clear, so I assume you're talking about the built-in flash.
The only way to force the built-in flash to fire at full power is with a manual lens (a lens without A aperture setting, or with A setting but the aperture ring is not at A).
I wish there was a way to adjust the power of the built-in flash to 1/2, 1/4, ..... As far as I know, Pentax DSLRs up to and including the K10D don't have this provision.
I avoid the built-in flash as much as possible. If I need just a small flash, I use my little Pentax AF160.
11-19-2009, 01:16 PM   #3
Yes, I was speaking of the built-in flash.
You've answered my question: the built-in flash is indeed auto (except when used with a manual lens). I guess an external flash is the answer to the problem.
Thanks for your reply.
11-19-2009, 03:19 PM   #4
audiobomber's Avatar
QuoteOriginally posted by pentaxable Quote
I expect the flash would fire at full power in Manual mode (manual settings for aperture, shutter and ISO). Full power with the built-in isn't much though compared to an external flash.
11-20-2009, 11:19 AM   #5
QuoteOriginally posted by audiobomber Quote
If you are using a "modern" lens that transmits the f-stop to the body, the built-in flash will be in P-TTL mode. EVEN if you are using M on the camera to set the f-stop and ISO (and shutter speed, which has no bearing on flash exposure anyway )
Built-in flash sucks for a multitude of reasons, so it is generally a good idea to buy a hot-shoe flash as soon as possible if you care about the way your indoor pictures look
11-23-2009, 02:09 PM   #6
Thanks, obviously the only way to 'control' the flash is to use an external one.
amount, auto, camera, flash, k100, k100 super flash, light, pentax help, pentax k100, photography, sensor
magnifier for k100 super elbmd Pentax Camera and Field Accessories 0 05-06-2010 02:50 AM
K100 D Super T Edwards Pentax DSLR Discussion 3 03-06-2010 10:42 AM
k200D vs. K100 Super D LSC Pentax DSLR Discussion 2 07-27-2008 09:23 AM
Sigma 500 Super DG Flash Compatibility Question Taskinillusion Flashes, Lighting, and Studio 4 07-05-2008 04:59 PM
All times are GMT -7. The time now is 07:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
