Originally posted by trickashay Hello Out There,
I am attending a party tomorrow and am the designated photographer. The party will be in a low lit environment and obviously people will be moving around quite a bit. I dont want to use the flash as I've noticed that people get annoyed with that after awhile. I've played around with increasing the ISO which in turn increased the shutter speed, but not by much. Long story short.......is there a way to get good (preferrably great) photographs in this situation w/o the flash?
Any and all comments welcome.
Tanya
The short answer to your question is NO.
Euriditass had a good response, use a flash bounce off the ceiling or off a wall. If you want to reduce the impact on folks, you can do it in a select area of the room, increase ISO to something you know will give you acceptable noise like 400 ISO, and reduce the amount of flash power. He also mentioned a fast lens, f2.8 is a minimum, but anything faster is helpful. (i recently took some scrooge pictures at a cemetery using ISO 3200.
There is another marginal technique. Put orange tape reflective tape around the legs of a tripod (or perhaps a monopod) and put it somewhere in the area where people won't be stumbling over it too much :-(. With a fast lens, reasonable ISO, you can sometimes get by with shutter speeds about 1 sec or less. Don't use a 2 sec delay, and perhaps a finger on the shutter or a cable will allow you quick shutter response. With a speed about 1 second, you will occasionally get a good shot, but many will be fuzzy, arms moving, talking will give you some fuzziness. Shutter speeds have two purposes, reduce blur from moving subjects, like humans, and giving the sensor enough time to record an image.
I think you will be far happier with the results if you take infrequent bounced flashes off the ceiling. Infrequent so you aren't irritating folks too much, some actually feel complimented by it. If you are going to take bounced flashes, be sure to set the iso down where your camera won't produce excess noise.
Whatever you choose, go to the site or set it up at home and try out your equipment and settings in advance. Can;t recommend this too much.l
I think low light situations like this is why folks get so excited anytime the ISO celing is pushed higher, as in the Kx. Its always been a weakness.
Phil
