11-20-2009, 09:00 PM   #1
Can't get RAW from K-x working?
I'm trying to use RAW mode, but can't seem to get the images to open in Windows.
I installed a WIC codec from the Pentax site, and also the Fastpictureviewer WIC codec pack from Fast Picture Viewer | WIC RAW Codec Pack for Windows 7, Vista and XP
I can see a preview of the images (and they look good, dammit!! ) but can't open them in Photo Viewer.
I get an error that says "The file may be unsupported, damaged or corrupted"
Similarly, if I try to open them in CS3, I get an error.
I'm wondering - has the RAW format changed for the K-x?
can anyone suggest what I need to install to be able to use/manipulate these .PEF files?
11-20-2009, 09:26 PM   #2
There's always slight changes to the RAW format with each new model it seems.
Your PENTAX should have come with a disc containing the PENTAX Photolab?
(I have a K-7 and haven't installed anything from it either )
Best bet would be to save as .DNG rather than .PEF then you should be fine with CS3.
The .PEF you have already can be converted to DNG with the free DNG Converter from Adobe.
Also, the free RAWTherapee may handle your .PEF (it supports the K-7)
11-21-2009, 08:53 AM   #3
Wheatfield's Avatar
The K-X PEFs will never, ever work with CS3.
At some point a codec might be released to allow Windows to thumbnail the things, but it might be a while, or it might not happen at all.
Just shoot DNG and get on with life.
11-21-2009, 07:51 PM   #4
Thanks for the input guys - I used DNG Converter to change my existing issues...
Then spotted a new update on the Pentax site (19th November - only 3 days ago!) that has an updated raw codec - which supports the k-x in windows, and the CS3 WIC import.
now my only problem is that I dropped the camera last night, trying to get some night sky pictures
11-22-2009, 05:49 AM   #5
QuoteOriginally posted by TheoJones Quote
You can also use Google's free Picasa 3.5, I do not have a K-x, but it should work
PEF files on my K10D and K-7 are much smaller than the DNG files, so I prefer PEF.
You can convert PEF files to DNG in any later point in time using Lightroom.
Try the Lightroom 3.0 beta release for instance and see how that works for you.
Be aware that Lightroom does many, many more things than just showing images.
11-22-2009, 06:03 AM   #6
I'd also recommend making your K-x save RAW format files as DNG. DNG is much more widely readable and is a good archive choice too.
Picasa works fine with K-x DNG's, fwiw. As does other freeware like FastStone Image Viewer and IrfanView. DCU 4.11 also works too of course.
camera, codec, error, images, k-x, pack, pentax help, photography, viewer, windows
Working with RAW format wshi Troubleshooting and Beginner Help 4 02-01-2010 04:36 PM
survey: batteries working/not working with the K-x noou Pentax DSLR Discussion 25 12-03-2009 02:43 PM
Does the Photoshop RAW converter work with Pentax RAW Files? mconder Pentax DSLR Discussion 3 05-15-2008 12:14 PM
working in raw momtographer Pentax DSLR Discussion 21 05-15-2008 08:13 AM
All times are GMT -7. The time now is 02:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
