Originally posted by Canada_Rockies Set the camera to get the exposure that Marc used in M manual mode. Set the flash to -2, then see what you need to adjust to get the effect of Marc's shot with flash to clear up some of the details.
Thanks for the tips but I still don't quite understand why we need to set the flash to eV of -2.
In manual mode, say we want a depth of field of say F3.2. We press the green button (on the K-7 for instance) to determine the shutter speed. If the shutter speed is low enuf, this would mean that sufficient ambient light is entering into the sensor, no? If the shutter is not too low, and we are comfortable that we can handheld without contributing to camera shake, then that shutter speed is selected. If not, we select a higher iso to compensate.
This will allow the camera to properly expose with the ambient light but at this exposure we might still think the photo is too dark. So we put on a P-TTL flash and set it to fire automatically in PTTL mode. The flash should then act as a fill flash automatically and working with the exposure we just set, correct? Why would we need to adjust the eV of the flash to -2?
Sorry. I am really not good in flash photography. I am trying to learn. 2 books are on their way
