11-24-2009, 06:04 PM   #1
How to find original filename vs that tagged by Lightroom?
I just realized that Lightroom is sequentially naming all of my imported photo's regardless of whether I shot them with my K20D or my little P&S.
I would like to know what the actual 'original' filenames/count were from the K20D. I would have thought this would be found somewhere in the metadata but I can't seem to find anything resembling a count outside of the filename given by Lightroom.
Help?
Thanks,
Ken
11-25-2009, 01:08 AM   #2
marcb
Guest
If you've converted your original PEF files to DNG, you do get the original file name (in Metadata Set "All"). FWIW, I always store the raw file name in the IPTC transmission reference field.
11-25-2009, 12:55 PM   #3
Venturi's Avatar
File renaming is not automatic in Lightroom. The default setting is to use the original file name. When you open up the "Import" dialog look for the "File Naming" option; set it to "Filename" to leave the original file names intact.
camera, filename, filename vs, k20d, lightroom, pentax help, photography
Resetting the filename counter-sequence for the pictures filename brosen Pentax DSLR Discussion 2 10-25-2009 07:51 AM
K-7 filename counter AndoS Pentax DSLR Discussion 8 09-29-2009 05:21 PM
I'm tagged! Nesster General Talk 2 09-30-2008 12:41 PM
How to find original retail price of lens? jsherman999 Pentax SLR Lens Discussion 2 09-19-2008 02:24 PM
Where to find an original MX soft case heartattackandvine Pentax Film SLR Discussion 10 09-16-2008 05:39 AM
All times are GMT -7. The time now is 06:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
