11-27-2009, 06:58 PM   #1
fusionimaging's Avatar
Exposure Time
Hey guys,
I was wondering if there is any way to program my k20 to shoot a 2 min. or longer exposure? I'm pretty sure there is way, as I have heard people doing 1-2 hour exposures, but I can't seem to figure out how. Thanks in advance.
11-27-2009, 07:31 PM   #2
You must use the "Bulb" mode for exposure times greater than 30 seconds. You can't "program" an exposure time in this mode. The shutter remains open for as long as the shutter release button is depressed. Or, you can use a remote with a locking button.
11-28-2009, 10:46 AM   #3
Set the camera to B for bulb mode and you pretty much have to use a stopwatch as a reference for longer exposures. Mind you if you're going that long you're probably set to a low ISO and the difference of a few seconds or even minutes when you get into hour long exposures is not a huge difference.
Bear in mind though that the K20 defaults to a frame subtraction which means the camera will be occupied taking a second black frame of equal length. So a 1 hr exposure means the camera won't be available for a second frame until 2 hrs later. A few people have gotten around this by taking multiple 29 sec frames and then stacking them in photoshop. Just something to keep in mind.
11-28-2009, 01:15 PM   #4
Ash
Community Manager
Ash's Avatar
Get a cable release that has a lock down shutter release feature.
Then with stopwatch/alarm (or just plain old watch) in hand, lock the shutter open in Bulb mode and wait...
11-28-2009, 02:20 PM   #5
Ok, I'll look into a remote with a lock feature. Thanks for the info guys.
11-29-2009, 01:31 PM   #7
Awesome! Thanks for the info.
camera, exposure, pentax help, photography
how to bracket exposure time? Urmas R. Pentax DSLR Discussion 4 02-01-2010 07:31 AM
K20d/K7 maximium exposure time? Luke_ Pentax DSLR Discussion 3 09-21-2009 10:53 AM
Long time exposure must use NR? yipchunyu Pentax DSLR Discussion 21 06-21-2009 05:08 PM
Trouble with Exposure Time jcleary47 Photographic Technique 7 06-17-2008 04:24 AM
Exposure time limitation while using manual lenses? ruff Pentax DSLR Discussion 9 05-20-2008 03:02 PM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
