Originally posted by Jori Here is a sample of a picture I took in auto pict and it randomly messed it up but a couple pics later it was working fine again...
Image info-
PENTAX 1/8s
K2000 f/4.5
FOCAL LENGTH 28.1mm
ISO 800
35mm equivalent : 42mm
first, you need to read about the basics of exposure: how ISO, aperture, and shutter relate to each other. Many people recommend "Understanding Exposure" by Bryan Peterson, so that would be a good place to start. but there are, I'm sure, decent explanations of these parameter online. Just Google "exposure aperture shutter speed iso" and check out any of the first few hits that come up.
What you'll find is just as I predicted. Your lens is presumably the 18-55, and it has a maximum aperture of f/4.5 at that focal length. Since your ISO is set to 800, and there wasn't a ton of light, 1/8" is simply trhe shutter speed the camwra needed to use in order to get a good exposure. If you want a faster shutter speed, you need more light , or else a higher ISO or larger aperture. And larger aperture (smaller f-number) means buying a new lens. So start by either adding light (eg, flash), or by raising ISO when shooting in low light in situations where you don't want to use flash. Most likely, you were in auto ISO mode, but there is an option somewhere to set the highest ISO the camera will choose, and I'm guessing that was set to 800. Change that to 1600 or higher if you wish to stay in auto ISO mode.
Also, it would help slightly to zoom out a little to get the focal length below 28mm, because then the camera could shoot at f/4 instead of f/4.5, which would help a little tiny bit. But ultimately, if you do much low light shooting, you'll want a "faster" lens - one with a larger maximum aperture, like f/2.8 or better.
