Originally posted by jonnyp Im looking for a filter to stay on my lens 24-7 to protect it. I went to the camera shop and came back with a tiffen UV Haze 1 filter. Im not sure if I got the right one? I don't want to filter to limit the light getting in to my lens. Im just looking for a layer of protection. What is the difference between UV and UV HAZE 1?
UV1 is CLEAR
"HAZE" may be another name for a UV filter.
Your best bet for protection is a filter that is multi-coated on all elements/sides. But, that will cost you..for 58mm and under..expect to spend $40-$60 Tiffen uses the HMC label for theirs. But, the MC filter will afford the best flare control..Make sure that the lens hood, if it connects using the filter threads, won't cut the corners off your image at the wide angle settings.
