12-04-2009, 01:20 PM   #1
Light Meter won't work on my Asahi Pentax KX
Hello all,
Allow me to preface my question by stating that I'm new to this site and a novice. I have an Asahi Pentax KX 35mm from 1977, I just replaced the batteries and I still cannot get the light meter to operate. I've tried everything the manual specifies and nothing has worked. The camera appears to be in great condition and except for the light meter, it seems to operate perfectly, according to the guy at the camera shop, who couldn't get it to work either. If anyone can help it would greatly appreciated.
Thank You
Anthony
12-04-2009, 02:01 PM   #2
Just1MoreDave's Avatar
Easiest thing to check is corrosion in the battery compartment. If that's not it, I would take off the bottom plate of the camera, probably only three screws. (I've never seen an actual KX but on other K series, the center screw is different then the outer two.) There's a wire running to the battery compartment. A leaking battery can corrode this wire enough so it breaks off right where it attaches. Reattaching is sort of annoying. The connector is stainless steel, so it doesn't dissolve under corrosion. It's pretty hard to solder, though.
12-04-2009, 02:45 PM   #3
Nesster's Avatar
First triage: you must have the wind lever pulled out some - if you're left eyed, it pokes you - for the meter to turn on. But as you've read the manual, I'm guessing you know this already.
Second triage: read the manual where it explains how to check battery power. Are you getting any? If the indicator lights up, this could indicate something wrong with the meter circuit itself. If not...
Third triage: are the batteries in the right direction?
If all of the above doesn't work, and the corrosion thing doesn't seem to apply, you might consider sending the camera to Eric:
Home
12-04-2009, 03:14 PM   #4
Steinback's Avatar
When you are looking through the viewfinder, does pressing the battery test botton cause the meter needle to move from the top to the bottom of the view finder frame?
If not then you have a battery problem (most likely) or (much less likely) there is something seriously wrong with the metering circuit.
If the battery test works alright then half cocking the wind lever and half pressing the shutter button should turn the meter on.
On the positive side of things, the KX only needs a battery for is the meter so if you are willing to use a hand held meter the camera should still be quite useable.
asahi, asahi pentax, camera, kx, light, light meter, meter, pentax, pentax help, photography
Asahi Pentax Meter on S1a tommessenger Pentax Film SLR Discussion 10 04-27-2011 07:18 AM
Repair Asahi SPII My Light Meter 3RiC Pentax Film SLR Discussion 3 11-02-2009 12:14 AM
Asahi SPII My Light Meter Isn't Working. Cameron030293 Pentax Film SLR Discussion 7 10-13-2009 06:46 AM
Would an Asahi Pentax flash (AF200s) work with my K200D? causey Flashes, Lighting, and Studio 2 09-14-2009 09:13 AM
Asahi Pentax ME, Light Meter not Working MacetheAce Photographic Technique 12 10-04-2008 02:31 PM
All times are GMT -7. The time now is 11:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
