Originally posted by Shooter I appreciate everyone's input so far. LeDave can you tell me why you suggest I go with the K-x? Is it just based on budget alone?
The K200D isn't supported by Pentax anymore because it's been replaced by the K-x and the K-x will continue to have firmware updates and more support by Pentax.
I've seen people upgrade from a K10D to a K-x, and that tells a lot especially when the K10D is above the K100D. Although the K100D does have weather-sealing and top LCD, it is a no-brainer for me to choose the K-x over the K100D anyways, it's overall just a more refined camera in almost every aspect possible. It does have newer technology after all.
The things to consider are also improved autofocus, higher dynamic range, more frames per second, hd video recording, live view, significantly improved high iso noise levels, lighter weight, and some more I can't think of. Trust me the K-x although is not weather-sealed does not feel cheap at all, I used to own the K-m and the reinforced polycarbonate plastic feels very sturdy and solid in my hands. I'm not going to lie to you, it feels just as solid as my K-7 only that my K-7 has an magnesium alloy body instead of polycarbonate. If I were to compare them regardless of materials used, I would say the K-m is just as good and the K-x uses the same body as the K-m.
You said this is going to be your first DSLR right? Well to tell you this, there are people out there who are upgrading from supposedly higher-end cameras and "downgrading" to the K-x, and there are some people who are upgrading from the K200D to the K-x. Sure the K200D is still a good camera, and it's not bad for the pricing right now. But if you are going to spend a lot of money, you might as well step up to get a K-x because it is very well worth it in every way imaginable. The pricing of the K-x is less than 600 w/ kit lens and it includes a robust sensor that is basically the flagship of Pentax high ISO and will probably be the most successful Pentax DSLR to date. The sensor used in it could be the next epitome of all APS-C, and in the direction shown so far, it very might as well be.
The K-m was my first DSLR camera and it's body is similar to the K-x, only the K-x is bassically a monster in the inside compared to the K-m. The lack of AF indicators and weather-sealing didn't bother me much at all. The lack of AF points is the least of my worries because I got so used to using the K-m without it, I don't even pay attention to the AF points in my K-7.
