12-09-2009, 04:59 AM   #1
rustynail925's Avatar
To Turn on Dust Alert
I tried cleaning the sensor following the instructions on the manual but after i finish i cant go to the Dust Alert Option. It skips it. Anyone here knows how to enable it?
12-09-2009, 08:05 AM   #2
Wheatfield's Avatar
You need an A type lens (A, FA, DA, DFA). If the lens has an aperture ring, set it to A. The AF must be in either AF.s or C and the camera cannot be in movie mode.
12-09-2009, 08:40 AM   #3
Mine is a kit lens. DAL 18-55mm
12-09-2009, 08:49 AM   #4
Wheatfield's Avatar
QuoteOriginally posted by rustynail925 Quote
Well, that would be a DFA, right?
12-18-2009, 07:29 AM   #5
How do you clean the sensor? do you use a cotton buds and wipe it ?
12-18-2009, 11:20 AM   #6
Marc Sabatella's Avatar
Don't touch the sensor with anything not designed for that! Most use rubber blower bulbs available at any camera store; some use compressed air, although most recommend against it. This subject has been discussed dozens of times here; please browse or search the forums to check out the tons of existing information and advice. The search phrase "sensor cleaning" turned up a bunch of relevant threads when I just tried it a moment ago.
12-18-2009, 11:25 AM   #7
enoeske's Avatar
The dust alert function will not be "chooseable" again until the file containing the dust alert image is deleted from the memory card. Hook up to a PC and delete the dust alert folder.
12-19-2009, 11:16 AM   #8
Thx Guys !
camera, dust, pentax help, photography
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
Dust Alert chris9486 Pentax DSLR Discussion 3 01-24-2010 04:19 AM
dust alert houstonmacgregor Pentax DSLR Discussion 0 07-10-2009 07:51 AM
Dust Alert audiobomber Pentax DSLR Discussion 2 10-19-2008 02:16 PM
Dust Alert on K20D Jewelltrail Pentax DSLR Discussion 13 09-19-2008 08:28 PM
All times are GMT -7. The time now is 04:51 PM. | See also: NikonForums.com, part of our network of photo forums!
