12-09-2009, 01:54 PM   #1
[langtitle=nl]color red shows as purple[/langtitle]
I just bought a k20d and joined the forum and I already have a question.
The red in all my photographs (so far only taken inside and in evening) show an awfull color red. Bright red shows as puple.
What are the best default color settings? I placed all color setting under the functionskey in the middle and selected 'natural'. White balance is on Auto. Still no bright red.
Is there a setting I am missing??
12-09-2009, 02:58 PM   #2
QuoteOriginally posted by pieterpost Quote
Pieter, I suggest you try and use RAW shooting.
You can later change all the colour settings in post processing.
Otherwise, take a photo first, alter the colour settings (for instance to artificial light) on the camera and you will see the effects it would have had on the previous picture. That way you can preview the effects.
Good luck, Bert
12-09-2009, 03:19 PM   #3
audiobomber's Avatar
No current camera works perfectly under artificial lighting. Assuming your room is lit with incandescent lights, you need to change the setting from AWB to Tungsten white balance. Or as Bert said, shoot raw and post-process.
12-09-2009, 05:27 PM   #4
Marc Sabatella's Avatar
Part of the problem is the Auto WB, which has to guess at the color of the light and is easily by really intense colors. Shoot a red object and the camera has no idea is that's a red object in white light or a white object in red light, so it tries to compromise. The solution to this is to set WB manually (either using preset or actually using manual WB), or to shoot RAW and correct the WB later.
Another part of the problem is that all color is made of red, green, and blue components, and when shooting a bright object, the red channel may get maxed out ("clip") at a point when the picture is still underexposed. if oyu expose the picture to look good overall, the red channel may be *very* clipped - meaning the camera basically had to ignore/throw away a lot of the red because it couldn't handle any more. A solution to this is to deliberately underexpose to avoid clipping the red channel. The histogram on the rear LCD is your friend here - specifically, the version of the histogram where it shows you red, green, and blue channels separately.
Another part of the problem is that your camera LCD and computer monitor are very likely lying to you abot the color, unless you have calibrated your monitor using a hardware device liek the Spyder or Huey. So the picture might indeed be red, but your monitors is off and is making it look too purple. The solution is, obviously, to calibrate your monitor.
camera, color, pentax help, photography
Acquisto pentax negli Stati Uniti e garanzia Internazionale Mitch Photographic Technique 3 12-07-2010 03:16 AM
Macro Premières photos avec mon K-7 YOYO31 Post Your Photos! 6 11-28-2010 05:35 AM
ufraw ubuntu red is green kjells Digital Processing, Software, and Printing 18 11-05-2010 08:56 PM
Optio W90 purple stripes in movie clips uuderzo Pentax Compact Cameras 7 08-03-2010 12:37 AM
Sports Women's football - Santos FC Champions Cup Brazil 2009 Pedro Ernesto Guerra Azevedo Post Your Photos! 1 12-02-2009 10:02 PM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
