12-10-2009, 09:09 AM   #1
Overexposing film.
I just read that it may be desirable in older film cameras to set a lower ASA/ISO than actually being used.
As it is easier to work with (develop)overexposed film than the opposite.
The reason given that light meters may not be perfect.
Any thoughts.
Thanks.
12-10-2009, 09:42 AM   #2
The best way to know is to shoot a test roll with the given camera. Take identical shots of a subject both witht he "correct" exposure as indictaed by the meter and one deliberately underexposed. Pick a variety of subjects, light and dark. Then see what you get. Otherwise, it's just a guess.
12-10-2009, 10:10 AM   #3
Eruditass's Avatar
He's thinking of overexposing, not underexposing, though the test would be similar.
I think this works a lot better for film, which compresses the highlights.
12-10-2009, 11:02 AM   #4
SpecialK's Avatar
If in doubt, overexpose negatives, underexpose transparencies.
12-10-2009, 11:39 AM   #5
Wheatfield's Avatar
True to an extent, but not for the reason given, and only for print film.
Slide film doesn't stand much exposure error, and really doesn't like being over exposed at all.
12-10-2009, 08:22 PM   #6
you 'over-expose' negative film to capture shadow detail. You develop your film so as not to 'blow out' the highlights. This is the basis of the 'zone system'. There are some tests (film speed test & normal development test) to determine your personal EI for a film and 'normal' development time. Film speeds are determined using a test in lab, not the real world. Although the zone system is more relevant to sheet film, determining your film speed and development is still a good idea for roll film users as you'll end up with negatives that are easiler to print (and scan if that's what your doing). After all, if it's not on the negative, you won't get it onto your print!
camera, film, pentax help, photography
K7 overexposing w/ Manual lenses??? JeremeyN Pentax DSLR Discussion 6 04-19-2010 06:22 PM
K20D overexposing with Sigma 17-70 rupi Pentax SLR Lens Discussion 3 11-11-2009 04:24 PM
Newbie SLR film and film develop qestion winglik Pentax Film SLR Discussion 11 06-15-2009 03:13 AM
SMC-F 50mm/1.7 Overexposing all shots s4v8 Troubleshooting and Beginner Help 11 05-22-2009 04:48 AM
favourite film camera and other film cameras? k100d Pentax Film SLR Discussion 54 03-25-2009 09:13 PM
All times are GMT -7. The time now is 02:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
