12-11-2009, 01:55 PM   #16
miss_alexx's Avatar
Ok I did the ruler test.
In M mode I see a huge difference in DOF between the two aperture values. (This time I set the ISO at 1600 in order to have a correct exposure even a f/22)
In Av mode there is no difference in DOF between the two aperture values.
12-11-2009, 01:57 PM   #17
kevinschoenmakers's Avatar
QuoteOriginally posted by miss_alexx Quote
This is to be expected. In Av-mode only the biggest aperture can be used (in this case f1.7). So when you want to use any other aperture you need to set your camera to the M-mode.
12-11-2009, 02:00 PM   #18
QuoteOriginally posted by matiki Quote
How is that?
For starters, shutter speed priority (Tv) mode isn't even available for m-series lenses. Second, she said she set the aperture to f22 and then pushed the green button, giving her a shutter speed of 0.4". If indeed she had exceeded the ISO-limit, the shutter speed should be at it's minimum, namely 30".
What she encountered was simply faulty metering.
12-11-2009, 02:02 PM   #19
miss_alexx's Avatar
I understand now. Thank you to all who helped me!
I've been using a 50mm f/2 in Av mode for at least one month... I did not notice that the Av mode was not really working...
12-11-2009, 02:02 PM   #20
matiki's Avatar
QuoteOriginally posted by kevinschoenmakers Quote
A mistype. Sorry. Aperture priority.
Last edited by matiki; 12-11-2009 at 02:14 PM. Reason: self remedying some rudeness
12-11-2009, 10:56 PM   #21
Just1MoreDave's Avatar
You aren't the first to make that mistake, and won't be the last.
aperture, camera, depth, f/1.7, field, lens, pentax help, photography
Depth of Field Calculator barbosas Photography Articles 19 02-11-2010 12:09 PM
depth of field rattrap Troubleshooting and Beginner Help 9 10-28-2009 11:20 PM
calculating the depth of field rustynail925 Troubleshooting and Beginner Help 18 10-06-2009 05:31 AM
depth of field dafiryde Pentax SLR Lens Discussion 4 11-05-2008 01:21 PM
Depth of Field Table? naturalog Photographic Technique 6 05-20-2008 11:59 AM
All times are GMT -7. The time now is 07:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
