Originally posted by bogiesbad I have a Vivitar 2x Macro TC and a Panagor 3x Macro TC.
1) Does the TC value increase the minimum focus distance? Would a 50mm w/2x TC achieve the same magnification at the same distance as a 100mm macro?
Yes, if you mean distance from the lens.
Quote: 2) Does the 2 or 3 stop reduction of light count as stopping down the aperture with regards to a lens' "sweet spot"?
Yes in principle, but the image may be degraded by the TC (at least the diffraction disk's diameter is also multiplied by the TC; depending on the sensor resolution this may shift the sweet spot to a wider aperture.)
Dave in Iowa
